Is there any diff.
Hey is there any diffirence in torque response on a D15B Vtec and my old D15B7!!! I mean it still laggs when take off or when accelerating!!! also could be of timing or is it cuz i havent swapped ecu's even though i have the P28 chipped but havent put it on also no Vtec wired up!!!!! Any help is appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK »</TD></TR><TR><TD CLASS="quote">its a single cam your not going to feel much torque</TD></TR></TABLE>expletive that sucks i mean ive seen other single cams take off better could the base maps of my current ecu be holding back my new motor!! Also i have a Greddy Turbo Kit which im just finishing buying other parts for it well i feel a big diffirence then!?
well when its boosted you will feel the diff. the ecu could cause it to run a little weaker cause of diff. base maps. when you put in your p28 you will feel a difference. not much but it should feel smoother. just get it tuned after you boost it and ride out, it will be fun. a buddy of mines had one boosted and it was a pretty fun car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK »</TD></TR><TR><TD CLASS="quote">well when its boosted you will feel the diff. the ecu could cause it to run a little weaker cause of diff. base maps. when you put in your p28 you will feel a difference. not much but it should feel smoother. just get it tuned after you boost it and ride out, it will be fun. a buddy of mines had one boosted and it was a pretty fun car.</TD></TR></TABLE> Thanx For the reply i will look into changing my ECU!!! As for boost i need to read more so i can do the **** right!
i did (blowup my SOHC) but i was going b-series anyway, take your time and make sure the kit is complete and that you have about 600 dollars extra incase **** breaks
averyvm
Jul 2, 2007 01:31 PM
