IAB secondaries - how-to tell if they work
Old May 16, 2007 | 07:42 PM
celestialcivic91's Avatar
Default IAB secondaries - how-to tell if they work
hey everyone,
was wondering if someone would be kind enough to let me know how to tell if the IAB's are working or not???
does the car have to be under load and will they open when the car is sitting and being revved
i just completed a swap and i want to make sure they are working
any help would be appreciated
thank you
M
Old May 17, 2007 | 10:17 AM
sauceja's Avatar
Default Re: IAB secondaries - how-to tell if they work (celestialcivic91)
They open at around 5800 and believe they are controlled by vacuum.
Doubt they will work sitting still but guess you could try.
A manual should tell you how to test them but I haven't messed with mine.
Old May 17, 2007 | 04:36 PM
Default Re: IAB secondaries - how-to tell if they work (sauceja)
thanks alot buddy
any idea where i could find this manual?
M
Old May 17, 2007 | 05:16 PM
builthatch's Avatar
MiG-21 superfan
creep around in this link and see what you can find-
http://www.redpepperracing.com...a-FSM/
Old May 17, 2007 | 05:59 PM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by celestialcivic91 &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot buddy
M</TD></TR></TABLE>
No problem
http://www.helminc.com
Old May 22, 2007 | 08:07 AM
IN VTEC's Avatar
The IAB system only has two states:
solenoid circuit is ON, and butterflies are closed to short, high-rpm runners when RPM &lt; 5750
solenoid circuit is OFF, and butterflies are open to short, high-rpm runners when RPM &gt; 5750
The system is normally open, so the secondary butterflies are open whenever vacuum isn't being applied to them to hold them closed.
The solenoid pulses to apply vacuum to the IAB diaphram to keep the butterflies in the closed position.
If you are uncertain as to which diaphram position is open or closed, then apply another vacuum line (e.g. FPR vacuum-reference line) to the IAB diaphram and you'll see the diaphram move to the closed position.
JDM_SOHC
Mar 15, 2007 07:26 PM
Duster
Honda Motorcycles
Jul 24, 2006 03:43 PM
v-tec maz
Nov 17, 2005 02:38 PM
akteamster
Dec 21, 2004 04:04 PM
-Trinitron-
Jul 8, 2004 06:05 AM
