Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
A miracle has happend to gear throws...
Old May 16, 2007 | 06:06 PM
Blackline47's Avatar
Default a MIRACLE has happend to gearbox?why?....
OMG today when i was coming back from work. i noticed my gear bow throws were sooo smooth. smoother than EVER before. WTF why isent like this all the time? i would turn gay for it to be like all the time. I did give my car a Idle 10 minutes before i even started driving. Do you guys know if any methods to keep your gear box to smooth like that!? i was so amazed i could'nt stop driving!
Modified by Blackline47 at 7:20 PM 5/16/2007
Modified by Blackline47 at 7:42 PM 5/16/2007
Old May 16, 2007 | 06:10 PM
freakvision03's Avatar
Default Re: A miracle has happend to gearbox (Blackline47)
this happens to me sometimes but i notice when it does happen, it's really warm outside like in the mid 80's. what was the temperature outside when you were in your car?
Old May 16, 2007 | 06:12 PM
It was around 60 Degree's F. when i was driving. Yeah im sure temp has something to do it with to
Old May 16, 2007 | 06:30 PM
Floopale's Avatar
same thing happens to my car in the mornings when I let it idle sometimes but the result seems consistent if i do some heavier driving on the transmission such as shifting in the high rpms and what not and also after i take a longer interstate trip.
Old May 17, 2007 | 09:03 AM
Declectic's Avatar
Default Re: a MIRACLE has happend to gearbox?why?.... (Blackline47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackline47 &raquo;</TD></TR><TR><TD CLASS="quote"> i would turn gay </TD></TR></TABLE>
whoa EASY tiger.... this is a car forum!!
Old May 17, 2007 | 10:39 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackline47 &raquo;</TD></TR><TR><TD CLASS="quote">OMG today when i was coming back from work. i noticed my gear bow throws were sooo smooth. smoother than EVER before. WTF why isent like this all the time? i would turn gay for it to be like all the time. I did give my car a Idle 10 minutes before i even started driving. Do you guys know if any methods to keep your gear box to smooth like that!? i was so amazed i could'nt stop driving!
Modified by Blackline47 at 7:42 PM 5/16/2007</TD></TR></TABLE>
What is a gear bow throw?
Old May 17, 2007 | 11:01 AM
N4me (06civicsi)'s Avatar
changing the mtf helps a lot my tranny feels like its spanking new
Old May 17, 2007 | 02:33 PM
Kiwibird83's Avatar
Reigning GDD Queen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackline47 &raquo;</TD></TR><TR><TD CLASS="quote">OMG today when i was coming. I noticed my throws were sooo smooth. smoother than EVER before. WTF why isent like this all the time? i would turn gay for it to be like all the time. I did Idle 10 minutes before i even started driving. Do you guys know if any methods to keep your box to smooth like that!? i was so amazed i could'nt stop driving!
Wowza, its brimming with undertones.
Old May 17, 2007 | 02:47 PM
Demonis's Avatar
Default Re: (N4me (06civicsi))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N4me (06civicsi) &raquo;</TD></TR><TR><TD CLASS="quote">changing the mtf helps a lot my tranny feels like its spanking new</TD></TR></TABLE>
isnt it spanking new?... a year tops? lol
Old May 17, 2007 | 05:17 PM
anavrin351's Avatar
Default Re: (Demonis)
i changes mine and it stopped the 3rd gear issues, but its still kinda notchy. used normal honda fluid
Old May 17, 2007 | 06:58 PM
its just random... one day it will be knotty and annoying. one day the gears with throw smoother than butter.
Old May 18, 2007 | 10:39 AM
BrokenHead's Avatar
The same thing happens with my FA5. When it's hot out, like 80F plus in the afternoon and the sun has thoroughly baked the car and blacktop, the gears and clutch are very smooth driving around. However, when I drive to work in the mornings recently, it's anywhere from 50-65 outside and the shifter is rough and the clutch is grabby, I have to slip the clutch a little longer starting out and be more careful changing gears. Also, when the motor is cold I get the notorious surging throttle, which is pretty wild for my experiences with Hondas. It behaves almost like a purpose built racecar in a way. It's annoying, but it makes feel "factory modified" in a way.
Old May 18, 2007 | 02:34 PM
anavrin351's Avatar
Default Re: a MIRACLE has happend to gearbox?why?.... (BrokenHead)
the surgimg throttle is the drive by wire system. it only happens to me when the car is completely cold.
Old May 19, 2007 | 11:41 AM
Default Re: a MIRACLE has happend to gearbox?why?.... (anavrin351)
bump ^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenHead &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happens with my FA5. When it's hot out, like 80F plus in the afternoon and the sun has thoroughly baked the car and blacktop, the gears and clutch are very smooth driving around. However, when I drive to work in the mornings recently, it's anywhere from 50-65 outside and the shifter is rough and the clutch is grabby, I have to slip the clutch a little longer starting out and be more careful changing gears. Also, when the motor is cold I get the notorious surging throttle, which is pretty wild for my experiences with Hondas. It behaves almost like a purpose built racecar in a way. It's annoying, but it makes feel "factory modified" in a way. </TD></TR></TABLE>
DeDonDeRosa
49
Jun 17, 2007 07:29 PM
halfcard
May 14, 2007 03:31 AM
disguy409
Nov 5, 2002 07:39 PM
