Is this normal?
Old Nov 4, 2002 | 07:09 PM
disguy409's Avatar
Default Is this normal?
I can take my car out of gear easily while its in gears 2-5 at certain rpms without using the clutch.....I was wondering if this is normal or is there something wrong with my car..Thanks
Old Nov 4, 2002 | 07:16 PM
:jdmshmaydm:'s Avatar
Default Re: Is this normal? (disguy409)
I can pull my car our of fifth gear right into neutral. I don't think nothing of it. I haven't tried it from 2nd though. I didn't even mean to pull it out it just sort of happened I guess.
Old Nov 4, 2002 | 08:33 PM
andrewM's Avatar
Default Re: Is this normal? (Gatecrasher18AF)
i can take it out of gear in any gear as long as its at about 1k rpm or under. in fact, i always do this when coming to a red light.
Old Nov 5, 2002 | 05:51 AM
disguy409's Avatar
Default Re: Is this normal? (andrewM)
thats good to know I'm not alone...It just happened while I was in 5th and then I tried it on the other gears and the same thing happened...
Old Nov 5, 2002 | 06:27 AM
fuguman's Avatar
New User
yes, have the same thing. its normal. oh, and LEARN HOW TO TITLE THREADS!!!! no one can search for this now, thanks alot.
Old Nov 5, 2002 | 06:35 AM
MrBite's Avatar
I can upshift and downshift without the clutch
yes it's normal
Old Nov 5, 2002 | 06:38 AM
Ohlias's Avatar
Default Re: Is this normal? (MrBite)
I always thought you were able to pull out of ANY gear at any speed as a saftey feature. Just in case the clutch goes....
Old Nov 5, 2002 | 07:54 AM
JMX's Avatar
JMX
Default Re: Is this normal? (Ohlias)
its called having good synchros
Old Nov 5, 2002 | 07:55 AM
VTC_GsR's Avatar
Default Re: Is this normal? (3232xmj)
It's great to shift without the clutch...but its tricky in 2nd
Old Nov 5, 2002 | 05:58 PM
smallttocs's Avatar
Default Re: Is this normal? (VTC_TeG)
its normal
Old Nov 5, 2002 | 06:08 PM
Sukebei Oni's Avatar
shifting without the clutch is ok to do as long as you don't grind the gears, if you have good syncros. i like down shifting from 3rd to 2nd without the clutch. sometimes i go threw the gear when getting on the freeway without the clutch.
but i use the clutch when racing, feels safer
Old Nov 5, 2002 | 07:07 PM
kappa's Avatar
yes it is normal .. just dont do it, it's not advised
[Modified by kappa, 4:07 AM 11/6/2002]
Old Nov 5, 2002 | 07:29 PM
mugenracer's Avatar
Default Re: Is this normal? (kappa)
i had a MK1 golf years ago, and after about 150k could shift in and out of gears without clutching, it saved me a fortune on those pesky rubber pedal covers
Old Nov 5, 2002 | 07:39 PM
azzenco's Avatar
Default Re: Is this normal? (mugenracer)
So to shift out of gear without the clutch you just pull it out of gear real hard?
jsantosDC5
Aug 21, 2006 02:14 PM
ap1_driver
Honda S2000
12
Jun 18, 2006 02:14 AM
hooptie157
May 20, 2002 07:31 AM
TypeR01-424
Nov 26, 2001 12:31 PM
