rev problem
Old May 16, 2007 | 06:02 PM
hany's Avatar
Default rev problem
i just install sohc vtec zc in my crx 1989., this motor is brother of d16z6 same pistons,rods,cranck, the only diff, i notice that this engine has no oil vtec pressure switch
i swaped to obd1 and use the stock ecu for that motor p70
the problem is i can not rev past 3500 rpm ., and cel is jumping but i can not check the cel code for some resons.
so my question is what can i check to solve that problem ?
Old May 16, 2007 | 06:04 PM
Micha's Avatar
FAILWGN
Default Re: rev problem (hany)
It is running in limp mode for some reason.
Old May 16, 2007 | 06:05 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: rev problem (micha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by micha &raquo;</TD></TR><TR><TD CLASS="quote">It is running in limp mode for some reason. </TD></TR></TABLE>
x2. Check and make sure you have the right ecu for that engine and that you have all the necessary sensors hooked up. A knock sensor or especially an o2 sensor that's reading improperly or not reading at all can send your car to ****.
Old May 16, 2007 | 06:06 PM
Micha's Avatar
FAILWGN
Default Re: rev problem (ek forever guy)
Wait... you switched the motor to OBD1 how? But you are still using a OBD0 ECU?
Old May 16, 2007 | 06:13 PM
hany's Avatar
yes i did not connect my o2 sensorto the harness . may be it ?
iam not sure if it has knoking sensore or no but i think no is not ?
micha:Wait... you switched the motor to OBD1 how? But you are still using a OBD0 ECU?
for sure no the car was obd0 and i change it to obd1 to can install my obd1 p70 ecu
Old May 16, 2007 | 06:22 PM
hany's Avatar
r u sure man if i did not connect my o2 sensore to harness can cause that problem ?
Old May 16, 2007 | 06:25 PM
Micha's Avatar
FAILWGN
If you don't connect your O2 sensor it will make your car run in limp mode.
Old May 16, 2007 | 06:30 PM
hany's Avatar
ok i will do it.,
there are a problem will face me ., this engine is one wire o2 sensore and i use the d16z6 harness which have 4 wire for the o2 sensore ., so what should i do ?
Old May 16, 2007 | 06:35 PM
Micha's Avatar
FAILWGN
There is a thread somewhere that shows how to change it over. You will have to search for that though.
Old May 16, 2007 | 06:39 PM
hany's Avatar
ok man thanks alot for helping you seem to be good and kind man
last question
is this motor sohc vtec zc jdm which came with p70 ecu have knoking sensore ?
and if you dont sure please tell me where to locate it and i will check it .
Old May 16, 2007 | 06:46 PM
Micha's Avatar
FAILWGN
I am trying to find the answer now.
Old May 16, 2007 | 07:00 PM
Micha's Avatar
FAILWGN
Everything I have searched for and looked at points to the P70 having no knock sensor.
Old May 16, 2007 | 07:03 PM
hany's Avatar
ok man ., i will start with my o2 sensor today., then i will tell you the result
thank you
Old May 16, 2007 | 07:06 PM
Micha's Avatar
FAILWGN
No prob. Good luck.
Old May 17, 2007 | 01:48 AM
hany's Avatar
i checked it today ., and its not o2 sensor at all ., its bad distributer
thank you man
music462
Aug 31, 2008 06:12 PM
. a d a m
May 11, 2008 11:47 AM
zxc4
Nov 17, 2005 06:27 AM
h22egAZ
Nov 1, 2005 10:48 PM
suprman1124
Aug 13, 2004 05:16 AM
