95 coupe Integra dash swap question(searched)
ok. i have searched for about 3 days now... i put the integra dash in my car, using the teg wiring. I DO have turn signals, hazzards work also..... BUT, i have no tach, no spedo, no gas gauge, and no temp gauge. i re-pinned the gray plug and that was it..... BUT, i went off a wiring diagram for the back of the gauge cluster, not the actual diagram for the plug itself. My question is, does anyone have the diagram for the gray plug? i have searched and the closest thing i could find was the cut and splice, BUT i already took all the wires from the gray plug...... so yea, a diagram from the civic gray plug would be graet. thank you all
FIRST OFF DID YOU REMOVE EG DASH PROPERLY
HERE IF YOU DID NOT TRY AGAIN...>>>> https://honda-tech.com/zerothread?id=600430
HERE LOOK HERE AS WELL
https://honda-tech.com/zerothread?id=285567
AND HERE ANOTHER PERSON HAD PROBS...BUT PEOPLE HELP HIM...
https://honda-tech.com/zerothread?id=170977
thanks for the help, but all those use the civic harness and change the plugs in the back of the cluster. i used the integra harness. it was very easy, BUT i have not been able to find a diagram for the single gray plug that you have to re-pin and plug into the fuse box. the integra plug is one more row too long, and it will not fit. i though it was stupid to cut and splice and solder everything togeather, so i re-pinned... i have gotten on alldata at school and can not find the color of the wires that are suppost to be in the gray plug. they all have the numbers. THATS IS. numbered 1,2,3,4,5, ect. its stupid. anyway. any help would be greatly appreciated.
motoxx644
Jun 9, 2008 12:27 PM
PDXHatchback
25
Apr 4, 2005 08:32 PM
Ls1 FD3s
Feb 12, 2005 01:12 AM
B18Cej1
Mar 30, 2004 08:42 PM
