92 Honda civic too much brake pedal
Old May 16, 2007 | 04:29 PM
94gsxturbo's Avatar
Default 92 Honda civic too much brake pedal
Have a 92 honda civic with gsr swap. Bled all brakes, new Master cylinder( bench bled), rear drums adjusted. No visible leak with brake booster. Shoes in rear are near end ( not sure of specs but most likely below.) No leaks visible in brake system. E-brake works fine/ok.
The brakes depress all the way to the floor and braking is slow( with car on.)
With car off brakes operate normally.
Any help/ideas, thx
Car also idles at 1-1.5, and over 1.5 when cold.
Old May 16, 2007 | 04:58 PM
abusedhusband's Avatar
Default Re: 92 Honda civic too much brake pedal (94gsxturbo)
my method is to get a friend, put line locks on all 4 brake rubber lines. step on pedal and see if fine, if not problem is the mc. if fine pull one off at a time and feel the pedal drop. a little drop is normal but not much. never fails. when pedal goe to floor you know where your problem is.
Old May 16, 2007 | 05:01 PM
94gsxturbo's Avatar
so it would indicate bad caliper/drum?
I already replaced mc.
rockrig
Nov 21, 2011 02:01 AM
bonspeed
Dec 20, 2009 12:34 PM
94gsxturbo
May 16, 2007 04:26 PM
JZA70
Nov 14, 2006 11:16 AM
GdmLaz
26
Aug 12, 2005 01:51 AM
