Best way to pop this dent out??
long story short, someone hit my car in a parking lot and dipped out. doesn't look like a car hit it due to the fact that there is no scratches or scuffs.
whats the best way to pop this back out? i know no matter what i do it will still leave creases and dimples.
I would try to attempt removing the interior and pushing it out from the inside if its accesible, or check eastwood.com they have alot of body tools for paintless dent repair... they can be expensive but they will pay for themselves over time.
my friend your sorta SOL csause from what i see in the pic it looks liek its dented with your body line is even if you push or pull it out it will always show you can work it so you cant see it much but never to where it was
this might work to make it look better, but it wont get that body line perfect. looks like there is a pinch in the dent. only way to get that out is a hammer and dolly.
but try this. get some of that dust off spray. equipe yourself with a heat gun. spray the **** out of the dent with the dust off for about 20 seconds. it will get extremely cold. then turn on the heat gun and keep it about 2-3 inches away from the panel. it should pop the dent out, but the creases will still be there. but its better then leaving it. theres a video on you tube that had some show how to do it.
do what heavyprok said take out the inside pieces in the trunk. take a dolly not hammer get a rounder one and just slightly start tapping it out. get a heat gun. keep it on the area for a few minutes then just tap it out soem more. but there will be a crease since there is a pinch in the dent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heavypork »</TD></TR><TR><TD CLASS="quote">I would try to attempt removing the interior and pushing it out from the inside if its accesible, or check eastwood.com they have alot of body tools for paintless dent repair... they can be expensive but they will pay for themselves over time. </TD></TR></TABLE>
Interesting, I've heard you should never attempt PDR without the proper training.
JBirch_97Prelude
Jun 1, 2006 09:15 AM
