h23 timing question
Old May 16, 2007 | 03:47 PM
mixmastermatt's Avatar
Default h23 timing question
im trying to time my h23 and i set everything tdc and ive been handturning the crank to see if im hitting the pistons to the valve. My cam shafts are about 45 degress away from making a full turn around. any idea on how to get that lat 45 degrees.
Old May 16, 2007 | 03:51 PM
mgags7's Avatar
Your timing belt is on, you haven't messed with cam gears or the crank gear, and your cams don't make it fully around? WTF?!?!?
Old May 16, 2007 | 03:54 PM
Default Re: (mgags7)
yeah it does make it around because the valve are hitting the piston
Old May 16, 2007 | 03:59 PM
mgags7's Avatar
dude wtf are you talking about?
your first post said its not making it all the way around.
why are your valves hitting the pistons?
Old May 16, 2007 | 04:30 PM
yeah my cam gears are not making a full rotion because the valves are hitting the pistons. ive got the timing belt hooked up
Old May 16, 2007 | 06:12 PM
mgags7's Avatar
did you build it or do cams or something?
if not your timing is just off.
Old May 16, 2007 | 06:27 PM
BlownH23a
Guest
Posts: n/a
NANI KOREWA! How can your cams not make a full rotation?
Old May 16, 2007 | 09:09 PM
Hawkze_2.3's Avatar
Default Re: h23 timing question (mixmastermatt)
What are you doing?! If the cams are hitting the valves (how do you know anyway), then you have a serious problem and you don't need to turn the engine over by hand.
Take the belt off and redo the timing until you get it right.
JJexpress
Jun 15, 2009 08:52 PM
Bumteg
Feb 3, 2009 11:00 AM
JohnD1079
Nov 6, 2007 10:49 AM
mstewar
Jul 11, 2005 11:24 AM
vtec4gcivic
Feb 3, 2004 07:42 AM
