For those of you wth Z10 trac. bars, need a quick answer!!!
Old Jun 1, 2002 | 08:29 AM
VTC_CiViC's Avatar
Default For those of you wth Z10 trac. bars, need a quick answer!!!
I just got around to instaling the Z10's last night on the Civic, pretty straight forward with a couple hiccups here or there, nothing major (had to hack my charge pipe right off the turbo to clear the Z10 support fame)..
Anyways, my question is, which way do I preload the LCA's?? The instructions tell you to turn the arms CW for give postivie caster, CCW for negative, but it doesn't specify which one i'm looking for? After installing them, I turned the arms till I found the "neutral" setting where I could feel zero resistance on the arm meaning the LCA was centerd, so what I need to know now is, do I pull the LCA to the front of the car to preload, or do I push the LCA towards the back of the car?? Any help would be apprieciated as always
Old Jun 1, 2002 | 08:46 AM
dustin's Avatar
Default Re: For those of you wth Z10 trac. bars, need a quick answer!!! (VTC_CiViC)
you want to pull the lcas toward the front of the car.
Old Jun 1, 2002 | 10:45 AM
SIK IN DA HED's Avatar
New User
Default Re: For those of you wth Z10 trac. bars, need a quick answer!!! (dustin)
do you think there will be a problem with the charge pipe getting in the way on my LS? i rather not hack anything...
Old Jun 1, 2002 | 11:48 AM
dustin's Avatar
Default Re: For those of you wth Z10 trac. bars, need a quick answer!!! (dlplayboy)
the pipes clear
Old Jun 1, 2002 | 12:21 PM
PureTeg420's Avatar
the pipes clear
pipes don't clear on a drag 3 ls. mine didnt fit w/o modification, and a little over a month ago i installed some for a friend of a friend and they didnt clear either. I don't understand why they fit on your GSR...that driverside u-bend piece should be indentical for both cars.
Old Jun 1, 2002 | 12:40 PM
VTC_CiViC's Avatar
Default Re: For those of you wth Z10 trac. bars, need a quick answer!!! (PureTeg420)
Well, mine fit on the Civic, but like I said, it was a TIGHT fit as you can see here:
[Modified by VTC_CiViC, 4:41 PM 6/1/2002]
Old Jun 1, 2002 | 02:26 PM
dustin's Avatar
I am using the maxrev manifold that positions the turbo differently, but I don't see how it is enough to matter...
Old Jun 1, 2002 | 02:30 PM
New User
the pipes clear
exactly what doesnt clear and what did you have to modify? how much did it cost for some z10 bars for a LS? i really want one of those so i dont get left behind at launches.
E-Rok
Welding / Fabrication
15
Mar 1, 2009 08:54 AM
bigkvn77
17
Oct 5, 2008 09:10 PM
Mad Vtack
11
Feb 5, 2006 07:43 PM
ChillOutWayne
May 14, 2004 08:45 AM
VTC_CiViC
Jun 1, 2002 01:21 PM
