installin clutch difficulty?
Old May 16, 2007 | 01:36 PM
rleonekc's Avatar
Default installin clutch difficulty?
94 civic ex 2 door 5 speed.
I'm swapping the engine out this weekend(because its bad) and putting a d15b in it. I'm using my old tranny and I was wondering how hard is it to do a clutch job while I got it all apart...and how long does it take?
Old May 16, 2007 | 01:37 PM
philosofy1's Avatar
Default Re: installin clutch difficulty? (rleonekc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc &raquo;</TD></TR><TR><TD CLASS="quote">94 civic ex 2 door 5 speed.
I'm swapping the engine out this weekend(because its bad) and putting a d15b in it. I'm using my old tranny and I was wondering how hard is it to do a clutch job while I got it all apart...and how long does it take?</TD></TR></TABLE>
if the motor is out the car and you are just replacing the clutch, then it's cake!
about 10 minutes, if that.
Old May 16, 2007 | 01:39 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: installin clutch difficulty? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
about 10 minutes, if that.</TD></TR></TABLE>
yep.
The lengthy stuff for changing a clutch while it's in the car are the axles, bitch pin, and the case.
Out of a car It's like philosofy said, Pastry.
Find a good writeup and go for it, I recommend replacing the TOB and input shaft bearing just because it's ~$20 in parts and you won't have to worry about them down the road.
Old May 16, 2007 | 02:36 PM
rleonekc's Avatar
Default Re: installin clutch difficulty? (ek forever guy)
Yehah ill look into that, were changin the clutch, pressure plate, throwout bearing
LS94tegra
Sep 7, 2007 08:08 PM
JDMPaulWall
Jul 7, 2006 12:16 AM
Gods own
14
Feb 24, 2006 06:50 PM
boostfed_coupe
Sep 26, 2005 09:50 PM
takendaily
Jan 18, 2005 05:56 PM
