2nd gear grind on d16z6 after clutch/fly/LSD install
Old May 16, 2007 | 11:28 AM
fanaticalK's Avatar
Default 2nd gear grind on d16z6 after clutch/fly/LSD install
I found some info on this on d-series.org but cannot log in anymore to repond to threads.
It is pretty much narrowed to the counter shaft bearing backing out and making contact with the ring gear. Fluid, motor mounts,shift bushings are all new and in good shape. The grind only happens on redline shifts into 2nd, all other gears are fine. It did not do this at all before my clutch, flywheel, and quaife were installed.
So my main question here is.....could the CSB backed during the install???
Any help is appreciated.
Old May 16, 2007 | 11:37 AM
JDM knowledge's Avatar
Default Re: 2nd gear grind on d16z6 after clutch/fly/LSD install (fanaticalK)
pm Bense.
Old May 17, 2007 | 09:01 AM
4g hatch's Avatar
is it a light flywheel. if so maybe since the motor is turning faster the syncro is having trouble engaging exspecially if it was wore to begin with. just a thought im no tranny guy
Kidnkorner
Honda Civic (2006 - 2015)
21
Aug 21, 2008 09:52 AM
FastReligion
Jul 10, 2006 10:42 AM
InfamousDC2FI
May 13, 2006 07:59 PM
redmethods
May 12, 2004 09:44 PM
BlackAC99
Aug 31, 2002 06:13 PM
