Please Help Me
Old May 16, 2007 | 10:39 AM
93 EG's Avatar
Default Please Help Me
I started my car last week and I had a very bad hesitation between 1-3k rpms. So I drove it and whenever I would pop into Vtec my car would hesitate like crazy. I checked my codes and I was throwing my MAP code and my IAT code. I replaced my map first and everything was still jacked, so I replace the IAT and unplugged the battery. Plugged everything up, start my car, and I still have the same hesitation so I turned my car off and I managed to burn the end of my IAT sesor and fry my ecu. What do you think could be the cause of this?
I have already changed my fuel filter, new cap, and new spark plugs. Thanks.
BTW: Its a b16a2
Old May 16, 2007 | 11:17 AM
93 EG's Avatar
Default Re: Please Help Me (93 EG)
bump
Old May 16, 2007 | 11:21 AM
97Ej6mike's Avatar
You did not reset the ECU correctly if you are still getting hesitation with a new MAP and IAT. IAT is an utterly useless Piece IMHO, i let mine just dangle down, from everything ive ever worked on, it has never affected anything performance-wise, at all, ever.
Old May 16, 2007 | 11:30 AM
93 EG's Avatar
Default Re: (97Ej6mike)
which way would you recommed resetting it?
Old May 16, 2007 | 11:31 AM
97Ej6mike's Avatar
Unplug the battery for 5 minutes, make sure everythigns plugged in correctly, always double check.
Old May 16, 2007 | 11:34 AM
93 EG's Avatar
I'll try that but do you think that if it wasnt reset correctly that could really burn my IAT sensor and fry my ecu?
toolbox21
May 8, 2010 09:17 AM
civic89si666
Dec 23, 2009 06:16 PM
b16jaf
Nov 30, 2007 03:17 PM
luciffer
Oct 4, 2005 05:44 AM
