97 CIVIC WITH 99 SI B16A2 SWITCHING TO JDM GSR OBD2
can I use my existing harness ( 99 si) on the jdm b18c? If I use the engine harness that came with the motor and plug it to the ecu side of my 99 si harness, with this be fully compatible without any modifications? HELP!!
You have to use your chassis harness, as this is the correct way to do it -- so yes, the SI harness. The integra harness won't just "snap in" and work. Plus, your SI harness doesn't have an "ECU side" since it's one piece. The teg harness, as you've noticed, is two pieces.
Awsome thanks, I thought I needed some major wiring work or had to go on a impossable search of obd2 gsr harness for a decent price...
thekid2390
Jun 18, 2013 11:36 AM
Sosa0311
Sep 15, 2012 11:14 AM
alien
Jun 13, 2006 01:36 PM
Unknown Member
Mar 25, 2003 06:53 PM
