i need some noob helpp
Old May 16, 2007 | 09:45 AM
ef.love's Avatar
Default i need some noob helpp
im a nooob n i need help.
when i start my car the first time of the day i see that one of my fuel injectors is spilling gas like hell. does this mean i need new fuel injectors or just my o-ring bad?
but when my car is warmed up, i start it and it doesnt do it.
Old May 16, 2007 | 09:46 AM
turbodcivic510's Avatar
replace the little rubber ring and make sure your running all your fuel line bolts and make sure there tightened down
Old May 16, 2007 | 09:47 AM
bigluelok's Avatar
Default Re: i need some noob helpp (ef.love)
change your o rings first and check if it still does that
Old May 16, 2007 | 09:49 AM
89efDUSTY's Avatar
Default Re: (turbodcivic510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodcivic510 &raquo;</TD></TR><TR><TD CLASS="quote">replace the little rubber ring and make sure your running all your fuel line bolts and make sure there tightened down</TD></TR></TABLE> x2 but also make sure you are checking both seals "into IM and into Fuel rail". Its probably a bad seal becuase when you car heats up the seal probably expands and creates the seal completely. They are pretty cheap from honda, I got mine wholesale though for like 1.50 a piece...d16y8. I think normal price is like 3 something. gl
Old May 16, 2007 | 09:52 AM
ef.love's Avatar
Default Re: i need some noob helpp (bigluelok)
aight kew that ***** buggin, i thought it was the o-ring buy well see when i replace it thanks though!
ooh yeah i got one more thing my thro shifter might be broken or something
when i put it in first gear the shifter still moves left n right hella loosely im not sure what to do, i replaced the bushing on the torque rod and i replaced the shift rod and its wierd n its hellla wierd
Old May 16, 2007 | 10:30 AM
CRX Toad's Avatar
O-rings would be my guess. Make sure everything is snugged down to proper specs on the fuel rail.
There is a bushing that is actually on the shifter it is white and you can get it at the dealership this maybe your issue.
Old May 16, 2007 | 10:31 AM
BIG_T's Avatar
Default Re: i need some noob helpp (CRX Toad)
its ur o-rings, there cheap at autozone
lamaZmia
Oct 12, 2014 11:26 AM
hYbRiD EeEkAy
16
Apr 19, 2008 12:37 PM
VTECth1s
May 7, 2006 07:29 PM
sleepereg6x
Nov 6, 2005 05:49 AM
EJ8VTEC
Sep 30, 2005 11:14 AM
