Good way to check Radiator Leak
Old May 16, 2007 | 09:13 AM
nik_gujarathi's Avatar
Default Good way to check Radiator Leak
I have 95 F22B1 CD5 Accord.
From last few weeks I have noticed drop in the coolent level. I did filled it up once, but I think there is leak in radiator.
Is there a good way to locate the leak?
Old May 16, 2007 | 11:14 AM
pos_cd5's Avatar
Default Re: Good way to check Radiator Leak (nik_gujarathi)
while the engine is running and warmed up look for visible leaks, streams of water, water dripping ontop ground, etc.
Old May 16, 2007 | 01:27 PM
The-Kid's Avatar
or go to autozone and rent a pressure tester. Pump it to i think 16 lbs. If it holds at 16, your system is ok. If it drops slowly find out where.
Old May 16, 2007 | 07:32 PM
JimBlake's Avatar
Default Re: (The-Kid)
Another reason to use a pressure tester...
When it's hot, the leaking coolant can evaporate quickly before you see it. Pressurize it cold & it can be easier to find the leak.
Mhillips
Jul 31, 2013 07:16 PM
daprchamp
Jun 11, 2011 04:14 AM
soon2bdropped
Jan 15, 2007 03:41 AM
Eibach95Civic
Aug 17, 2006 05:03 PM
PreIudeSI
Sep 2, 2002 04:50 PM
