After changing the ex. header...
Old May 16, 2007 | 09:05 AM
highvtec's Avatar
Default After changing the ex. header...
and complet exhaust the engine starts to run very RICH.
With a full tank I make barely ~350km/213miles!Before change the complet exhaust I was able to make ~450km!
What can be wrong?Lambda,itd?
It goes for a CIVIC with a B16 engine!
thanks in advance
Old May 22, 2007 | 09:42 AM
highvtec's Avatar
bump
Old May 22, 2007 | 06:10 PM
civicstar's Avatar
Default Re: After changing the ex. header... (highvtec)
depends on what exhaust system you have, if you are talking about the EX exhaust system in the 98-2000 models, the secondary O2 sensor is in the cat that is on the piping. some aftermarket system will cause it to run rich cause difference in flow/backpressure.
jthrasher1
Mar 2, 2010 12:12 PM
EM2junkIE
Honda Civic (2001 - 2005)
Feb 28, 2008 08:41 PM
gus738
Honda Civic (2006 - 2015)
Oct 13, 2006 07:37 PM
Valenzuela
11
Aug 25, 2006 06:46 PM
oxygen241
Oct 4, 2005 05:38 PM
