HELP ON MY SUSPENSIOIN !!!!
i just put on my GC today and the rear is hella low,but the front is one finger gap,so i had to raise up the back and make it even with the front,cuz i hate looking at the rear lower than the front.is there eny way i can make the front lower like the rear,becuz the front is already adjust down to the lowest,it can go lower but its just that the cup to hold the stock spring is the one stopping the one u torque down...so i was thinking to cut that cup so that the sleeve for the GC will go lower,and in that way it can be even with the back...what u guys think i should do?idk if it will get compress later but am thinking it wud b the same....
You have a sedan, correct?
Did you get the GCs for the sedan, or just for a 2001-2005 civic? Because if you put springs or sleeve coilovers designed for a coupe on a sedan, the rear will always sag.
i've actually heard of people doing what you want to do (remove the tophat that came with the GC's and use your stock tophat) with no problems. but i dont know how it rides.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m2s4drespecial »</TD></TR><TR><TD CLASS="quote">yep, i got a sedan and it's meant for the sedan my car is an 05 model.but i want the front to be atleast no finger gap.</TD></TR></TABLE>
You'll need more than just new springs to maintain drivability at that point.
09civicsi01826
Honda Civic (2006 - 2015)
May 9, 2011 06:35 PM
jimmy714
Mar 18, 2008 10:14 AM
MulletManRockStar
Sep 16, 2004 04:56 AM
AnitRiceSuperStar
Jan 22, 2004 03:02 PM
