electrical problem with a/c, mirrors.
i have a 93' delsol which i bought few months ago, which i currently almost finished pimping. when i took it the electricity was fine, a/c was working (i replaced the blower since), elctric mirrors were also working, but suddenly they're not working any more, the led lights on the a/c panel don't shine anymore, mirrors are lifeless. I checked the fuses under the steering wheel guided by the del sol diagrams here: https://honda-tech.com/zerothread?id=1966666, some fuses were misplaced but i've replaced them in their correct places, but it didn't solve the problem. iam desparately trying to geththe a/c to work as its getting rEalLy hot over here in Dubai!!!
some notable clues to the problem might be, the light in the left drivers door seem also affected, as when i press the button it shines for a while then goes off, if i i'd try again after a while the same thing would happen. i've also replaced the condensers fan, but no power is reaching that as well, although i remember it worked previously, but not anymore. i believe the problem is in one place, and if i can find it then they'd be working again...
i am basically hungry for any clue, i even spent countless hours in car electricians and a/c specialists workshops but all were in vein.
thanks in advance.
thanks in advance.
about the lights: try knocking on them (easily)...they might (probably) come to life?
as to others...seems like there is sthg wrong with electrics...do go to el. mechanic for that!
oh another thing i should also mention is that my headlight hi and low beam seem inverted, which means the lights are actually on low beam when the hi beam led in the bashboard is on, and vice versa, could this be causing the problem? i tried inverting the + and - wires in the bulb hose but didn't help.
iam sure the interior left door light problem i associated becs i tried changing the bulb and the same problem continues to happens.
electricians and mechanics have all given up and told me go elsewhere!!
so i am set to do it my self.
thanks!
so i am set to do it my self.thanks!
jdm_bones
Jul 31, 2006 10:01 AM
