anyway to get engine codes without light??
Old May 15, 2007 | 10:55 PM
b20accord's Avatar
Default anyway to get engine codes without light??
So just bought a ej2 coupe with b16a in it! And vtec doesnt work.. Im pretty sure its throwing a code but there is no check engine light and i think its because the guy that sold me it might of took out the bulb.. Or maybe the cluster that is in it doesnt pick up the check engine light the same way??
I have this cluster in it..
Is this a authentic jdm guage cluster?? And does it plug in the same?? Would there be any reason the check engine light wouldnt work??
So is there another way other then the light to check for codes?? Thanks!!
Eran's Avatar
HT White Ops
Take the CEL bulb out of your stock cluster and put it in the new one?
Old May 15, 2007 | 11:00 PM
ridin98civic's Avatar
Default Re: anyway to get engine codes without light?? (b20accord)
when you turn the car on does the CEL come on for a few seconds then go back off like its supposed to? thats the easiest way to tell if the bulb is missing.
Old May 15, 2007 | 11:47 PM
b20accord's Avatar
Default Re: anyway to get engine codes without light?? (ridin98civic)
sneaky bastards... Took it apart and the one bulb that was missing was the cel bulb..... And no wonder because it has 4 check engine lights!! code 7,21,41,10!! Damn it! lol!!
Old May 16, 2007 | 04:02 AM
blackKready's Avatar
thats no biggie dude. that looks like is a real JDM cluster though. looks to be , in km/h only and 8200 rpm redline instead of 8k even.
7-TPS-throttle postition sensor.
10-IAT-intake air temp.
21-VTEC solenoid
41-oxygen sensor heater.
you can test the sensors , but im thinking you could have some wiring issues. make sure the above things are plugged in. come back and tell us what you find.
Old May 16, 2007 | 10:31 PM
b20accord's Avatar
Default Re: anyway to get engine codes without light?? (blackKready)
hey guys.. The harness is pretty bad... So im thinking of using a ex harness on my dx. Will the ex harness work perfect for it?? Other then i will need to 2 wires for vtec at the harness that is by the firewall going to the ecu??
Old May 16, 2007 | 10:38 PM
dannis.'s Avatar
the ex harness will work perfectly!
Old May 16, 2007 | 10:46 PM
b20accord's Avatar
Default Re: anyway to get engine codes without light?? (dannis.)
cool thanks! Thats what i wanted to know!!
Honda904
Feb 19, 2014 11:14 AM
Beckerton
48
Jun 25, 2011 04:09 AM
94_DEL_SOL_VTEC
May 2, 2011 06:01 AM
90dteg
Sep 18, 2008 12:54 PM
crew08 (girlygirlracer)
23
Mar 24, 2005 02:54 AM
