Need to confirm how to mark flywheel for ignition timing on H22A
Old May 15, 2007 | 10:30 PM
pcguy760's Avatar
Default Need to confirm how to mark flywheel for ignition timing on H22A
I have an aftermarket flywheel in my H22A and it does NOT have the ignition timing marks so I am unable to set the ignition timing BUT recently I read that you can mark the flywheel with whiteout when you bring the No. 1 Piston up to TDC and you can use that whiteout mark to set your timing...
Can someone who has done this confirm with me this will work? Thanks.
Old May 16, 2007 | 01:46 AM
TheWalrus's Avatar
spark timing is supposed to be 15 degrees before tdc...your talking about marking it at tdc
get a stock flywheel and see how many teeth the tdc mark is from the timing mark
Old May 16, 2007 | 04:14 AM
pcguy760's Avatar
Default Re: (TheWalrus)
Anyone else who has done this before, can you confirm with me how to do this?
Old May 16, 2007 | 05:43 AM
Propulsion's Avatar
Default Re: (pcguy760)
I've never done this before, but I would think, after you mark TDC as described,
# of teeth are on the FW = N
360 /N = degrees per tooth = D
So if you wanted 15 degrees,
15/ D = number of teeth you need to move away from TDC.
Old May 16, 2007 | 07:05 AM
kulrevon's Avatar
Default Re: (Propulsion)
well you can mark it at TDC and just get a "good" timing light that is adjustable.
you should be able to get it within a few degrees. which I am sure is closer than what most people have theres set at.
Old May 16, 2007 | 10:40 PM
pcguy760's Avatar
Hmmm that makes sense... but I need to confirm, so after I mark the flywheel at TDC, I get an adjustable timing light and then set the timing light to the recommended specs or whatever setting I want the timing to be (15 BTDC for H22?), and then I advance or retard the distributor until the TDC mark that I made on the flywheel, lines up with the arrow or pointer right??
Thanks.
Modified by pcguy760 at 9:50 AM 5/18/2007
Old May 18, 2007 | 08:51 AM
pcguy760's Avatar
Bump to confirm lol
Old May 19, 2007 | 08:44 PM
pcguy760's Avatar
Does anyone know if this is correct ^
Old May 21, 2007 | 07:53 AM
pcguy760's Avatar
Default Re: Need to confirm how to mark flywheel for ignition timing on H22A (pcguy760)
Anyone?
Peter Brady onlyonweekndz
Dec 25, 2007 11:18 AM
pcguy760
May 22, 2007 09:50 PM
pcguy760
May 22, 2007 07:01 PM
sheBangZ
Sep 2, 2006 07:57 AM
