Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
is it possible to remove the speed governor on an 03 tl type s?
Old May 15, 2007 | 10:24 PM
vladd's Avatar
Default is it possible to remove the speed governor on an 03 tl type s?
a buddy of mine has an 03 tl type s and wants to remove the speed governor. is this possible? i've already emailed hondata and they said they don't have anything for this.
Old May 15, 2007 | 11:56 PM
YeuEmMaiMai's Avatar
Default Re: is it possible to remove the speed governor on an 03 tl type s? (vladd)
why would you want to go faster than 149mph? Car speed govenor is set there for a reason, most likely due to car starting to lift at higher speeds
The newer TL type S is capped at 137mph
the only way to remove the speed govenor is to reprogram the ECU as it is an electronic govenor
Old May 15, 2007 | 11:59 PM
vladd's Avatar
Default Re: is it possible to remove the speed governor on an 03 tl type s? (YeuEmMaiMai)
he just can't get enough i guess. not my car, just trying to help a friend out.
Old May 17, 2007 | 06:11 AM
dixie Normas7's Avatar
flash the ecu
Old May 17, 2007 | 09:01 AM
Kenso's Avatar
HT White Ops
Default Re: is it possible to remove the speed governor on an 03 tl type s? (dixie Normas7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dixie Normas7 &raquo;</TD></TR><TR><TD CLASS="quote">flash the ecu</TD></TR></TABLE>
The ECU is not "flashable" on the 2nd gen TL's unfortunately. I'm not aware of upgraded ecus for those cars either, not entirely sure since I've never searched for one, but don't recall ever hearing of it.
Old May 20, 2007 | 05:21 AM
Kevin's Avatar
Default Re: is it possible to remove the speed governor on an 03 tl type s? (Kenso)
Look into the Apex'i rev speed meter, it has a speed output which can be set to fool the ecu. This is how i got rid of the electronic governor in my Camry. HKS also sells a SLD speed limit defencer which may work as well and is about half the price.
Old May 20, 2007 | 03:13 PM
vladd's Avatar
Default Re: is it possible to remove the speed governor on an 03 tl type s? (gLok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gLok &raquo;</TD></TR><TR><TD CLASS="quote">Look into the Apex'i rev speed meter, it has a speed output which can be set to fool the ecu. This is how i got rid of the electronic governor in my Camry. HKS also sells a SLD speed limit defencer which may work as well and is about half the price.</TD></TR></TABLE>
thanks, the hk sld looks promising. i'll have to look into it
xero-cool
Mar 24, 2007 10:33 AM
fdjizm
Nov 29, 2006 02:32 PM
entityzero
Mar 15, 2006 08:27 PM
junek00
Sep 5, 2004 09:58 AM
Sergio61
10
Jun 28, 2004 10:07 AM
