Need help with my OBD 1 conversion
Old May 15, 2007 | 06:48 PM
freddysEF's Avatar
Default Need help with my OBD 1 conversion
Hey guys i want to convert my 1990 civic hatchback to OBD 1. I did a mini me swap on my car, a Z6 head on my D15 block. So i was searching on Honda tech and EF Honda and i couldn't find, what parts i need to convert my mini me to OBD 1. i know i need a obdo to obd1 harness but what else??
thanks
freddy
Old May 15, 2007 | 06:50 PM
ludesrv's Avatar
Hmmm...
http://www.rywire.com
Buy the kit, don't cut up your harness.
Old May 15, 2007 | 06:56 PM
freddysEF's Avatar
Default Re: (ludesrv)
ok i know that i need to get a harness from that site but what else
Old May 15, 2007 | 07:42 PM
crisco_inferno's Avatar
OBD-1 distributor and 4-wire O2 sensor
Old May 15, 2007 | 08:53 PM
danmdevries's Avatar
Default Re: (crisco_inferno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crisco_inferno &raquo;</TD></TR><TR><TD CLASS="quote">OBD-1 distributor and 4-wire O2 sensor</TD></TR></TABLE>
That's it. Just conversion harness, vtec head, dizzy and 4wire.
Oh, and an obd1 ECU.
It's really really easy if you have the conversion harness from rywire or whoever else makes em. Make sure you also have the vtec harness if that's not part of the rywire kit. I have a Frog conversion and it has a separate harness for O2/vtec solenoid
Old May 15, 2007 | 08:57 PM
dr_latino999's Avatar
Default Re: (danmdevries)
Slackers, DIY
Old May 16, 2007 | 01:23 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (dr_latino999)
you'll also want to repin your distributor or get a distributor adaptor and run the wiring for VTEC solenoid/pressure switch
Old May 16, 2007 | 07:31 AM
freddysEF's Avatar
whats a dizzy?? and should i get the harness with the Vtec wires. Is this one with the vtec harness?? http://rywire.com/store/obd0-o...f554f
Old May 16, 2007 | 07:32 AM
freddysEF's Avatar
Default Re: (freddysEF)
and also what are the 4 wires for the O2 sensor
si90rex
11
Feb 1, 2013 07:40 PM
lsvtec_hatchback
Aug 31, 2006 09:25 AM
faSHOwidIT
Jun 14, 2005 12:10 PM
type Gendy
May 9, 2005 12:04 PM
