90 CR-X SiR Sway Bar Links? What US Model Are They The Same As?
Old May 15, 2007 | 02:56 PM
crxforum's Avatar
Default 90 CR-X SiR Sway Bar Links? What US Model Are They The Same As?
Ok on my SiR I need to replace the sway bar links the only problem is that I have a different setup than US CRXs. The US one looks like a bolt with a bunch of bushings on it. Mine looks more like a bar bell with 2 cups on each end. Like a 300zx or newer Honda. The only problem is that I called a few local part stores where friends work and they say that they have no idea what I need.
Anyone have any suggestions? Its not a 91 teg or anything like that.
CRX Forum
Old May 15, 2007 | 03:03 PM
89efDUSTY's Avatar
Default Re: 90 CR-X SiR Sway Bar Links? What US Model Are They The Same As? (crxforum)
TTIWWP... gl finding it, but seriously a pic may help
Old May 15, 2007 | 03:38 PM
Fobtions's Avatar
Default Re: 90 CR-X SiR Sway Bar Links? What US Model Are They The Same As? (89efDUSTY)
i have the same problem as well. US crx's have what looks similar to skateboard truck bushings. that go through the lca.
You need some sort of linkage.
i wonder if the tanabe sway bar comes with the stuff?
this looks similar, its a rear link
Old May 15, 2007 | 04:13 PM
crxforum's Avatar
Default Re: 90 CR-X SiR Sway Bar Links? What US Model Are They The Same As? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem as well. US crx's have what looks similar to skateboard truck bushings. that go through the lca.
this looks similar, its a rear link</TD></TR></TABLE>
Thats the style I need right there. I called ICB Motorsports in Cali and they told me they would let me know in a few days if they can get it or not. I just have a long drive coming up at the end of this month and I need this fixed before then.
CRX Forum
Old May 15, 2007 | 05:20 PM
aarontrini85's Avatar
88 hf has the same lca's thats where i got mine
but i dont know if it has a sway bar stock. if it does im sure there the same
Old May 15, 2007 | 05:28 PM
Crx Jimmy's Avatar
looks like you could just use a male and female heim and screw them together then put bolts thru. maybe that can solve your problem
Old May 15, 2007 | 07:34 PM
crxcess's Avatar
Default Re: 90 CR-X SiR Sway Bar Links? What US Model Are They The Same As? (Crx Jimmy)
There was a setup like that on the front sway bar on a 2000 civic si I parted out.
Old May 15, 2007 | 11:09 PM
Dxs's Avatar
Dxs
https://honda-tech.com/zerothread?id=1853917
ED=USDM EF
Old May 16, 2007 | 09:47 AM
crxforum's Avatar
Default Re: (Dxs)
Ive ordered a 2001 Civic SiR (Si in the US) set of sway bar links. I hope that will work because they look the same.
CRX Forum
Old Sep 25, 2008 | 05:50 AM
luciffer's Avatar
Default Re: (crxforum)
I hate to bring this thread back from the dead, but I have the same problem and just wondering if anyone found something that works?
beebeecivic
Mar 10, 2011 03:21 PM
luciffer
14
Apr 8, 2009 05:34 PM
thatbluecrx
Dec 24, 2004 04:59 PM
tunes12
May 14, 2003 08:48 AM
