Quick question about my Head + Cams
Old May 15, 2007 | 01:42 PM
JDM_EK4_Coupe's Avatar
(banned)
Default Quick question about my Head + Cams
Ok, I recently installed S2S2 Cams, Valve Springs and Retainers. But before I installed them I had the head sent out and got it completely cleaned and resurfaced. It was milled too. Now I installed the cams and did the valve adjustment (.007 Intake and .008 Exhaust) and there is still a ticking noise from the engine. Would I have to adjust it a different way due to the milled head? Because I heard that someone severely damaged their engine because they didnt even know that their head was milled and installed the cams.
Old May 15, 2007 | 01:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: Quick question about my Head + Cams (JDM_EK4_Coupe)
I'm not certain what valve lash specs Skunk2 recommends for those cams, but you may want to contact the company to double-check.
As for the damage in you read about, that was most likely due to valve-to-piston contact caused by insufficient clearance when combining a milled head, aggressive cams, and perhaps high-compression pistons. It almost certainly had nothing to do with the valve adjustment.
Old May 15, 2007 | 01:53 PM
(banned)
Default Re: Quick question about my Head + Cams (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I'm not certain what valve lash specs Skunk2 recommends for those cams, but you may want to contact the company to double-check.
As for the damage in you read about, that was most likely due to valve-to-piston contact caused by insufficient clearance when combining a milled head, aggressive cams, and perhaps high-compression pistons. It almost certainly had nothing to do with the valve adjustment. </TD></TR></TABLE>
Ok, I double checked and those were the right specs.
My head is milled a bit and I do have S2S2 cams but I am running Stock SiR II Pistons (10.4:1) So do you think im in the clear?
Also, I did a little research and ive read that when you put a more agressive cam in it tends to make that ticking noise, is this so?
Modified by JDM_EK4_Coupe at 6:22 PM 5/15/2007
Old May 15, 2007 | 06:00 PM
(banned)
bump
Old May 15, 2007 | 06:07 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by JDM_EK4_Coupe at 6:22 PM 5/15/2007</TD></TR></TABLE>
correct, the rocker is hitting the valve harder. a little ticking is normal
Old May 15, 2007 | 06:21 PM
(banned)
Default Re: Quick question about my Head + Cams (Sleepy_Red_hatch)
Thanks
jpangeles
Jul 11, 2013 05:59 AM
Muckman
Apr 7, 2012 06:56 AM
psegs80
Oct 31, 2009 11:25 AM
rough_draft
May 16, 2005 12:49 AM
H22CL
Apr 27, 2004 03:19 PM
