width and offset help..
Old May 15, 2007 | 12:12 PM
efsteez's Avatar
Default width and offset help..
i am going to get work equip 03s for my ef. i want 15's but am unsure of the width and offset to run.
Old May 15, 2007 | 02:27 PM
r.wright's Avatar
Default Re: width and offset help.. (efsteez)
how low is the car ?
15x6.5 - 15x7
+35 to +45 and u should be fine
use the correct tire size though
Old May 15, 2007 | 03:42 PM
efsteez's Avatar
Default Re: width and offset help.. (mr. R*L*X)
what kinda tire sizes would i be looking at for a 15x7?
Old May 15, 2007 | 03:57 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efsteez &raquo;</TD></TR><TR><TD CLASS="quote">what kinda tire sizes would i be looking at for a 15x7?</TD></TR></TABLE>
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">
What size tires should I get?
The proper size depends on your car, not just the wheels you are using.
<FONT SIZE="4">For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16
</FONT>
For an Integra or '97-00 Civic, the following sizes are usually best:
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16, 215/45-16
17" - 205/40/17
I would get 15x6 or 15x6.5 wheels for your 195/50-15 tires. 15x7 will look too stretched.
Old May 15, 2007 | 06:22 PM
rare_db2's Avatar
Default Re: width and offset help.. (nsxtasy)
your width and offset depends on the look your going for, some guys are running 15x7 and a +15 or even a +0. there is some pics on here of ef's and da's w/rwd offsets it looks dope in my opinion. check it out under pic request.
Old May 19, 2007 | 10:15 PM
abcdefghij's Avatar
Default Re: width and offset help.. (rare_db2)
Sorry to hijack the tread but would 16x7s with a 32 offset fit my ef9?Cheers
Old May 22, 2007 | 07:23 PM
nerdytoes's Avatar
i'm about to purchase some rims but don't know can 15x8 with offset of +25 on the front and + 10 on the rear will fit my ride... its a 91 civic hb? any help will appreciated...
thanks
Old May 22, 2007 | 08:49 PM
toyomatt84's Avatar
Sanji
Default Re: width and offset help.. (nerdytoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdytoes &raquo;</TD></TR><TR><TD CLASS="quote">i'm about to purchase some rims but don't know can 15x8 with offset of +25 on the front and + 10 on the rear will fit my ride... its a 91 civic hb? any help will appreciated...
thanks </TD></TR></TABLE>
No, they won't. Not with some camber and a fender pull.
Old May 23, 2007 | 06:40 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: width and offset help.. (toyomatt84)
For a pre-'96 Civic, don't go wider than 15x6.5 (and 15x6 is even better). As noted above, you'll need 195/50-15 tires; they will look too stretched on 15x7.
Old May 23, 2007 | 02:48 PM
vtecsi00's Avatar
15x7 will work just fine with the right offset. But a 15x6.5 or 15x6 would be prefered for your application. 35mm to a 45mm offset would be ideal
the_dxB16
Mar 31, 2008 04:26 PM
Hondatuner88
Feb 3, 2008 08:45 PM
christ0pher
Nov 7, 2007 07:37 AM
themorphious
Jul 10, 2007 02:30 PM
JDMJNKY
Mar 18, 2007 04:07 PM
