really high fuel pressure
Old May 15, 2007 | 09:37 AM
4g hatch's Avatar
Default really high fuel pressure
since the other day my fuel pressure is really high. that morning it was 45psi at idle. by that night it was 70psi at idle. its got me confused. the b&m fuel pressure gauge is good i thought. i took off the aem regulator and put a factory one on still the same thing. checked all my vacums and pulled the spark plugs and they was'nt soaked with gas. does'nt seem to run bad but that pressure reading has me worried. i have a rebuilt ls if that makes any difference. do you think the gauge is bad could it b something else. any advice or suggestions would be appreciated since this is driving me crazy
Old May 15, 2007 | 12:52 PM
4g hatch's Avatar
bump
Old May 15, 2007 | 01:14 PM
gsrious's Avatar
might be the gauge.
Old May 15, 2007 | 03:38 PM
non-VTEC's Avatar
Default Re: really high fuel pressure (4g hatch)
sounds like your gauge is bad
Old May 15, 2007 | 05:58 PM
4g hatch's Avatar
that is what i was thinking but i didnt want to buy one if didnt need it. do you know any better brands than b&m. i really dont like it anyway
Old May 16, 2007 | 12:25 PM
sauceja's Avatar
Default Re: (4g hatch)
I run the marshall fuel guage and absolutely love it. No problems out of it and you can find it in the sponsor section.
Can't remember if alchemist or someone esle was selling it.
Old May 16, 2007 | 12:45 PM
4g hatch's Avatar
good to hear ill check it out. also are the b&m known for going bad or is this just bad luck
Old May 16, 2007 | 07:55 PM
JimBlake's Avatar
If you have a plugged or crushed fuel return tube, it'll behave just like that. And it'll still do that with a new FPR.
Got a MityVac?
Take off the FPR, reverse the MityVac so it pumps pressure (not vacuum). Pump into the fuel return line. It should pump air back into the gas tank without much resistance.
Old May 17, 2007 | 06:26 AM
4g hatch's Avatar
where could i get one. that's deffinatly a good idea. how would the line get bent or crushed it was fine. thanks for the advice ill check it soon as i can get one of those vac's
Old May 17, 2007 | 09:11 AM
JimBlake's Avatar
Well, the fuel return line goes along the bottom of the car, back to the tank. All you gotta do is kick up a stone in just the wrong place. Or bend the return line to fit a non-stock FPR & put a kink in the line.
Get a MityVac at your favorite AutoZone or wherever. But all you really need is some way to pump some pressure into the fuel return line. Even a bicycle pump with some clever way to attach it...
Old May 17, 2007 | 09:16 AM
4g hatch's Avatar
sweet. ill definatly check it out. wonder how bad it is to drive it like that.
Old May 17, 2007 | 07:54 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">sweet. ill definatly check it out. wonder how bad it is to drive it like that.</TD></TR></TABLE>I wouldn't just ignore it. If the return line is plugged with something, it'll just get worse.
Another way to check is disconnect the FPR from the return line. Put a hose on the FPR where the return line was, & put that in a gasoline can. Start the engine & watch the fuel pressure. If it's OK NOW, that proves it's a problem in the return line.
Old May 18, 2007 | 06:08 AM
4g hatch's Avatar
ill do that this weekend when i get a chance since i work long evenings. ill let you know what happens
Old May 21, 2007 | 08:46 PM
travis-b16a2-eg's Avatar
any of you guys know where i can get and adaptor that bolts to the fuel rail, i just got a fpr and the guy who sent it to me gave me the wrong peice that replaces the stock reg. i tried lookin everywhere but no luck, if you know anywhere hit me up
BJM3x96813
Engine Management and Tuning
Jun 29, 2014 04:13 PM
Bobby_Budds
Aug 17, 2011 04:08 PM
spidermancivic
Feb 23, 2005 09:48 AM
Lei Siew Long
Jul 1, 2001 03:11 PM
