How did this happen?
Old May 15, 2007 | 08:21 AM
ZippyZivic's Avatar
Default How did this happen?
I got my zc block rebuilt and it always smoked a little. i thought it was the seals or something but it got worse. i took off the head last night and found this. I have only been running the motor for like 3 months and not pushing it at all. Is this inproper installation of the shop? Thanks Guys
Old May 15, 2007 | 08:35 AM
djphonics's Avatar
Default Re: How did this happen? (ZippyZivic)
Are those stock rods? If so, it looks like the wrist pin didn't get pressed in the rod centered, and it's rubbing on the cylinder wall, or it somehow moved. Either way...no good.
If they're aftermarket rods and have a floating pin, maybe it's not secured properly.
Old May 15, 2007 | 08:54 AM
ZippyZivic's Avatar
Default Re: How did this happen? (djphonics)
yes their stock rods. So in other words the shop didn't do the job right? I just don't wanna get screwed and them tell me its my fault this happend.
Old May 15, 2007 | 09:21 AM
abnaasefmb's Avatar
yep, looks like a piston pin. i had a friends engine do this when he spun a rod bearing. i think in his case the rod got very hot, expanded and let go of the pin.
Old May 15, 2007 | 09:33 AM
burnt_rice's Avatar
that's a builder error take it back to them!!!!
Old May 25, 2007 | 05:53 PM
ZippyZivic's Avatar
Default Re: (burnt_rice)
little update. the shop is acting all retarded on me that this happend due to the fact that i let the motor overheat or the turbo made it happen im so freaking pissed off right now. the car never overheat and i never pushed the motor hard. is their any suggestions to what i can do or am i fuckd.
Old May 25, 2007 | 05:55 PM
SIred91's Avatar
Rainman
Default Re: (ZippyZivic)
You are fucked....sorry....
Old May 25, 2007 | 05:58 PM
abnaasefmb's Avatar
Default Re: (SIred91)
yeah i'm going to concur. you could bore it out and use 82mm pistons maybe.
Old May 25, 2007 | 06:22 PM
SIred91's Avatar
Rainman
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">yeah i'm going to concur. you could bore it out and use 82mm pistons maybe.</TD></TR></TABLE>
Ummm....you wont be getting 82mm pistons in a zc without an act from God.
Old May 26, 2007 | 06:13 AM
abnaasefmb's Avatar
i'm sure you could or just get some BBchevy pistons and throw em in, git r done.
Old May 26, 2007 | 06:20 AM
crxdxsir's Avatar
call your lawyer!!
MugenB16A2
Dec 1, 2003 08:15 PM
MugenB16A2
Dec 1, 2003 07:45 PM
aaj23
Jun 19, 2003 11:25 PM
advanracing62
Jan 6, 2003 10:35 AM
schwett
Apr 24, 2002 10:43 PM
