Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Door molding and pin stipes
Old May 15, 2007 | 07:05 AM
K24_Y61P's Avatar
Default Door molding and pin stipes
I heard a few ways to get these guys off, but i want to know exactly what im doing before i bring anything towards my paint.
Old May 15, 2007 | 07:40 AM
bioweapon's Avatar
Pin stripes can be removed with an 'Eraser' which is a rubber disc you put on a drill. Most body shops will be able to show you what it is because its kinda tough to describe.
For the door mouldings, you have to take the door panels off, and the plastic weatherproofing sheet under the panels. Youll see clips that hold the mouldings on, just pinch them with needlenose pliers and they will pop out.
Old May 15, 2007 | 07:44 AM
K24_Y61P's Avatar
Default Re: (bioweapon)
does the same apply for the pieces that are on the body panels too? after the doors
Old May 15, 2007 | 07:46 AM
bioweapon's Avatar
Where? I have an ES1 and there are no other mouldings other than on the doors. EM2 doesnt have any mouldings, does it?
Old May 15, 2007 | 07:48 AM
stinkypinky1011's Avatar
i took my pin stripes off by heating it up with a blow dryer and slowly pulling it off then hit it with some wax a few time after you got it all off and i looks like it was never there.As for the door moldings if its an older car and it came with it theres clip like bioweapon said and if it was an add on it could be just m3 tape.
Old May 15, 2007 | 07:51 AM
K24_Y61P's Avatar
yup they are on the body too take a look, old picture tho
Old May 15, 2007 | 07:53 AM
dont take your door apart, if you have an em2 there on there by m3 tape.
Old May 15, 2007 | 07:54 AM
bioweapon's Avatar
Those are just stuck on, probably with double sided tape. I didnt think EM2s came with that, stock, so its probably added on. I doubt they cut holes in the doors for clips.
Old May 15, 2007 | 07:58 AM
K24_Y61P's Avatar
they dont appear to be the same color of the car, they look darker depending on light. so what just take a heat gun to em and pry em off with a plastic wedge?
Old May 15, 2007 | 07:59 AM
bioweapon's Avatar
You got it. Maybe use a little goo gone to get rid of any residue from the tape, then make sure you put a couple coats of wax on right after.
Old May 15, 2007 | 08:04 AM
K24_Y61P's Avatar
dang that was easy, just went out there and stuck my finger in it and it popped right off....luckly she didnt take no paint.
thats right heat that thing up and find a way to get under it and slow pull it up but keep heating it because when it cools it harder to pull it off. try to heat the corner if it to get under it then keep heat it side to side slowly pull it up. the pin stripe is the same way.
Old May 15, 2007 | 08:15 AM
bioweapon's Avatar
Here is one of the decal removal tools.
Thats a pricey one cause it doesnt come with the hub, most of em are just a solid block of rubber. Should be able to find them at any automotive supply store where they sell filler/paint/etc. You heat up the pinstripe, and then put that on a drill, and it just rubs it off. They are fantastic cause they take the glue off as well, and dont damage any paint.
Old May 15, 2007 | 08:22 AM
K24_Y61P's Avatar
sweet, i will see if i can find one. btw i have em2 side moldings for sale
he doesnt need that all he needs is a blow dryer and his finger. heat the corner of it and pick at it till you get the edge up far enough where you and grab it and pull slowly but keep heating the stripe as you pull it off. its fast and easy. i did it to both my cars. it took like 10 min.
Old May 15, 2007 | 08:53 AM
K24_Y61P's Avatar
Im running out of things to use to get the tape residue off. used goo gone and bug and tar remover and it fails to come off. wondering if theres any home brewed remedies
Old May 15, 2007 | 09:00 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (ajgrosch716)
Coca-Cola is pretty good at removing/desolving most things, your teeth included. It's great for cleaning dead flies and tar and crap off so it might get the glue off? Mind you, it might peel your paint off too.
Old May 15, 2007 | 09:03 AM
K24_Y61P's Avatar
haha yeah it works great on chrome bumpers. dissolve one sticky mess to be left with a differnent sticky mess. only have pepsi though haha
Old May 15, 2007 | 09:04 AM
Newborn_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajgrosch716 &raquo;</TD></TR><TR><TD CLASS="quote">dissolve one sticky mess to be left with a differnent sticky mess</TD></TR></TABLE>
True, but you can rinse that off easily enough.
Old May 15, 2007 | 09:08 AM
K24_Y61P's Avatar
buddy is tell ing my gasoline and rubbing alcohol....ehhh?
Old May 15, 2007 | 09:12 AM
Newborn_'s Avatar
Google is your friend...
From here: http://www.ehow.com/how_13445_remove-stickers.html
"Remove stickers from glass, plastic or metal with alcohol-based products such as nail polish remover or 91-percent rubbing alcohol. Oil-based products such as cooking oil, mineral oil and baby oil can also be used. Apply the liquid to a clean cloth and saturate the sticker; allow it to sit for a minute or so and peel the sticker from the surface."
Old May 15, 2007 | 10:07 AM
K24_Y61P's Avatar
alcohol based products are fine to put on your paint? dont they eat it right off?
Old May 15, 2007 | 02:32 PM
cherrynutz's Avatar
I work at an autobody shop and I wouldn't use the rubber wheel. I just used a heat gun on mine and used goo gone. You just have to let the stuff sit on the glue for a little bit and use a microfiber with some tough love. Mine came out perfect.
Old May 15, 2007 | 07:31 PM
Harlowe's Avatar
Function>Fashion
Try WD40. It works good
Old May 16, 2007 | 06:49 AM
K24_Y61P's Avatar
Default Re: (Harlowe)
WD40 works the best by far. i been running around the garage throwing everything i got at it. WD40 is the only thing i has worked on it. thank you thank you
