AEM Engine Management System *pics*
I am selling an AEM Programmable Engine Management System. The model # is 1020. It replaces your factory ECU with a fully loaded control box that puts virtually every engine setting at your fingertips. It is in perfect working condition. Im asking $900 for it. If you have any questions about it feel free to call me at 727-744-3596
It will work on the following vehicles:
*96-99 Acura Integra
*96-98 Honda Civic
*96-99 Honda Prelude
*( It can be used on other vehicles with a jumper harness)*
The AEM Plug & Play Engine Management System is custom-made to replace your specific sport-compact or performance vehicle’s engine control unit (ECU)
Tune to your heart’s content—the Plug & Play EMS offers full control of virtually every engine parameter and setting
User-managed setting templates are easy to configure and use “quick keys” to access important data
The AEM Plug & Play stores a sea of data to provide all the engine information you’ll ever need
Load new settings, view data or download parameters created by other users—the Plug & Play interfaces with Windows systems through the serial cable port
The AEM EMS provides 357 different RPM-specific air/fuel ratio settings applied across the power band
Available with or without dual-wideband UEGO controllers for the most precise and advanced monitoring of your air/fuel ratio
Also tweak idle speed, rev limiters, injector fire patterns, wet/dry nitrous control, knock thresholds and traction control
The Plug & Play EMS comes loaded with 16 dedicated General Purpose Outputs (GPOs) and 7 switch inputs
Allows full control of many other settings (see “Detailed Info” link above)
Your Plug & Play EMS is backed by a 1-year warranty
Description:
Replace your limiting factory ECU in minutes, and take complete control of virtually every engine parameter under your hood. The AEM Plug & Play Engine Management System is a veritable mad scientist laboratory for tuning your performance vehicle’s engine. With thousands of combinations, the tweaking and tuning are limitless!
Use your Windows PC to load new settings for your engine, read data from the built-in data logger, or download fresh parameters accommodating your other performance upgrades.
Boost your power at any RPM. The Plug & Play EMS offers 357 different air/fuel ratio settings specific to rev points, and an optional built-in UEGO controller. Play with 10 different spark fire patterns, 5 rev limiter types and idle speed. Plus, wet or dry nitrous control!
Plan on making changes to your engine? No problem! The AEM forums community has tons of downloadable settings for the taking.
*96-98 Honda Civic
Description:
