Front end shaking when coasting, whats up?
Old May 14, 2007 | 12:52 PM
likenother's Avatar
Default Front end shaking when coasting, whats up?
I have a b16 swapped into my EK. Today I was out driving and I noticed when I let off the gas while the car is in gear and let it just coast, the front end shakes back and forth. When I put it into neutral and coast, it stops shaking. I also realized that it does not shake when giving it any gas, only when it is in gear and coasting. I checked tire pressure, and they are all good.
Anyone have any ideas? Thanks
Old May 14, 2007 | 01:01 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Front end shaking when coasting, whats up? (likenother)
i'm guessing....axle
Old May 14, 2007 | 01:27 PM
JDM-EJ698's Avatar
Default Re: Front end shaking when coasting, whats up? (Throwdown)
Maybe Motor mounts?...
deadline's Avatar
hows the bushing in the front...old..new..maybe replace some bushings
Old May 14, 2007 | 02:58 PM
Throwdown's Avatar
Default Re: (deadline)
axle FTW!!
Old May 14, 2007 | 03:00 PM
bleedblue94's Avatar
did you just swap it? if so make sure you fully tightened the axle nuts bc if there is any play then you will get vibrations ... otherwise it is most likely an axle or mount problem
Old May 15, 2007 | 05:45 AM
likenother's Avatar
Swap was done about a year ago, I was thinking it might be the axles, but I was out later in the day and it completely went away. Hmmm, time to tear down and check it out!
Thanks for the help guys, H-T Love!
Old May 15, 2007 | 02:36 PM
Default Re: (likenother)
please post your fix when you figure out the prob
Old May 15, 2007 | 08:33 PM
dub from laos family's Avatar
i had the same problem... it was my axles.. if u change the axles and it snaps again... change your half shaft
ERKK
Sep 18, 2009 03:00 PM
ToledoLude
May 21, 2009 11:31 PM
psegs80
Oct 3, 2007 11:31 AM
DC2SIR-G
Feb 23, 2006 04:30 PM
Deucers
Suspension & Brakes
Sep 19, 2005 03:31 PM
