vibration only when accelerating hard
my car vibrates when i accelerate hard.. what can the problem be? messed up suspensions? axles? alignment? its not my tires cuz they are new..
P.S would energy suspension motor mounts inserts help me out a lil on this?
Try accelerating, then let off the gas. If the vibration immediately goes away when you close the throttle, the problem is your inner CV axle joints. Raise the front end of the car and get underneath and grasp each inner axle joint and try to see which one has freeplay. There should be zero detectable free play (free play meaning the joint moving without the tire/wheel moving).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Try accelerating, then let off the gas. If the vibration immediately goes away when you close the throttle, the problem is your inner CV axle joints. Raise the front end of the car and get underneath and grasp each inner axle joint and try to see which one has freeplay. There should be zero detectable free play (free play meaning the joint moving without the tire/wheel moving).</TD></TR></TABLE>
werd.. it'll get really bad.. and then no telling when it'll bust.. my friend's db8 integra busted on the highway when we were all crusin.. and a big chunk blew off and hit some dude's winshield that we were crusin wit. he said he was gonna beat our ***, but guess not
wu tang
Dec 14, 2007 05:31 AM
baonest
Oct 23, 2007 08:08 AM
