reving
Old May 14, 2007 | 11:48 AM
kixcrx's Avatar
Default reving
ok so i just installed my motor into my car a d16a6 then when i started it the motor stayed reved to 2k rpm and thats how it stays it doesnt rev normal so then i checked for vaccum leaks but none so then i cover the throttle body to see if motor dies and it didnt the rev just went down a little what could be
Old May 14, 2007 | 11:49 AM
ludesrv's Avatar
A massive vacuum leak lol.
Old May 14, 2007 | 12:01 PM
kixcrx's Avatar
Default Re: (ludesrv)
so its a vaccum leak then right i thought it probably be a bad sensor could a bad sensor cause something like that
Old May 14, 2007 | 12:06 PM
89efDUSTY's Avatar
Default Re: (kixcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kixcrx &raquo;</TD></TR><TR><TD CLASS="quote">so its a vaccum leak then right i thought it probably be a bad sensor could a bad sensor cause something like that </TD></TR></TABLE> nope definitely a vacuum leak...spray carb choke or some use soap and water...but i think carb choke is better because it doesn't act as a fuel for the motor "explosions" it lowers the idle. Just spray and find it. My guess is probably the IM to head has the old gasket pieces still and is not letting the new gasket fully seal.
Old May 14, 2007 | 12:18 PM
kixcrx's Avatar
Default Re: (89efDUSTY)
maybe it could be the intake manifold gasket im going to check it to see if that was it
ajmj
Nov 22, 2005 05:12 AM
zensoku207
Mar 21, 2005 10:47 PM
hadehatch
Sep 30, 2004 07:57 PM
paul93sir
Feb 5, 2004 11:26 AM
SIK IN DA HED
Nov 21, 2002 03:21 PM
