Car won't turn on after sitting overnight
Old May 14, 2007 | 10:31 AM
coupedup's Avatar
Default Car won't turn on after sitting overnight
Car: 93 Honda Civic EX Coupe MT
Miles: 160k miles
Original Motor, Battery?(past 7 years), Alternator
Hey guys I know I haven't been around for awhile, but I've run into a major(for me) problem. A few nights ago I was at my friends house and went to go get ice and then the next morning at his house the car won't turn over. I can't remember if it even clicked or not since I was in a rush and luckily my was there and she drove me home. At first I thought I left the lights(HID) on, but turned the lights on and they worked perfectly. All of my dash lights work as well. We then tried to jump the car, but nothing happened. I've done searching and it seems like it could be the starter or distributor.
Is there anything else it could be or a better way to check to make sure? Its at a friends house at an apt complex which is over 40 minutes away so I wanted to go there with a lot of ideas and things to check for since I can drive back and fourth too much with the girlfriends car since she needs it.
Any help would greatly be appreciated!
Old May 15, 2007 | 05:19 PM
coupedup's Avatar
Default Re: Car won't turn on after sitting overnight (coupedup)
up... how hard is it to change a starter?
Old May 15, 2007 | 05:42 PM
muhaMan's Avatar
check for air in ur system.. i had air in my system and i couldnt drive my car for 5 weeks!! also check your main relay and try to hear if ur fuel pump is priming
Old May 15, 2007 | 05:53 PM
Boostedb20EH2's Avatar
Probably starter, not hard to fix.
Old May 25, 2007 | 08:41 PM
coupedup's Avatar
Default Re: Car won't turn on after sitting overnight (Boostedb20EH2)
Ended up being the starter... now I just have to find a way to get those 2 main bolts off. Hopefully some WD-40 works.
BlackKimera
Honda CR-V & Element
May 1, 2016 11:49 AM
mechanix619
Aug 30, 2007 11:43 AM
mechanix619
11
Aug 29, 2007 07:04 AM
donnnster
Sep 16, 2004 03:04 PM
CLICC916
Oct 17, 2001 09:24 PM
