B18 in a 93 LX
Old May 14, 2007 | 10:26 AM
projectpd's Avatar
Default B18 in a 93 LX
hey would the motor mounts from a b18A be the same as a d15b7 ? i know about the tranny but just saying would i need something else ? like relocation mounts ?
Old May 14, 2007 | 10:30 AM
pdiggitydogg's Avatar
why cant you people search.....and dont even say you did
One thread, out of hundreds on the same topic
https://honda-tech.com/zerothread?id=550976
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">First of all mounts:
For the timing cover side mount you will need to get the cast-iron bracket from any 1994-2001 Integra GS-R and also the aluminum mount as well. You can use the mount from a Del Sol VTEC as well, but not the 99-00 mount because it is totally different.
For the rear mount you will need to use a 1994-2001 Integra rear bracket. The actual rubber mount that bolts to the rear subframe can be the stock civic one. Check the 99-00 mount first and see if it will work too though before you go out and buy an Integra one. I used an Integra rear bracket on my fiancee's B16A2 swap in 1999, but the stock 99-00 one might work too.
The topside tranny mount can be the Civic VX one - it is the same thing.
The front mounting brackets need to be from an Integra 1004-2001, but if you want to keep A/C then get the A/C bracket for a Del Sol VTEC model. the actaul mounts that bolt to the underside of the framerails need to be the stock Civic ones.
92CiviC4dr
Mar 2, 2006 08:04 AM
EJCivJdM93
Feb 9, 2005 04:40 AM
TYPE_EG6
Jan 2, 2005 04:41 AM
JSPECHB
Jan 9, 2004 07:41 AM
jcivic
Feb 11, 2003 07:56 PM
