89 CRX and del sol, same suspension?
Old May 14, 2007 | 08:39 AM
1PT-SICK's Avatar
Default 89 CRX and del sol, same suspension?
i was looking up suspension and saw that CRX and Del Sol suspension has same part number for like skunk 2 springs.......can i switch my springs from my del sol and put them on my CRX and vise versa????
Old May 14, 2007 | 08:50 AM
CRX Toad's Avatar
Default Re: 89 CRX and del sol, same suspension? (1PT-SICK)
Yes, the springs are typically interchangeable
Old May 17, 2007 | 01:39 PM
1PT-SICK's Avatar
Default Re: 89 CRX and del sol, same suspension? (CRX Toad)
what about the shock and everything???? or can i just switch the springs?
Old May 17, 2007 | 02:00 PM
aarontrini85's Avatar
the only diffrance i have seen is the front forks would need to be swaped every thing else will bolt right up
Old May 17, 2007 | 04:39 PM
1PT-SICK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">the only diffrance i have seen is the front forks would need to be swaped every thing else will bolt right up</TD></TR></TABLE>
what??? now im confused!!! lol so can I switch my suspension from my CRX to my Del Sol? i dont understand what you mean by "switch the front forks"
Old May 17, 2007 | 04:51 PM
it will swap perfect but you need the front forks off a da or a ef
since the bore is a little smaller. if you use the forks off an eg or dc they are to big and wont hold on the struts they will slide off
hope that makes sence to you
Old May 17, 2007 | 05:06 PM
1PT-SICK's Avatar
Default Re: 89 CRX and del sol, same suspension? (aarontrini85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">it will swap perfect but you need the front forks off a da or a ef
hope that makes sence to you</TD></TR></TABLE>
alright i think i understand it now......let me just tell you what im doing....i drive my del sol everyday. it has nice suspension on it and i wanna put that stuff on my CRX and put stuff from my CRX on to del sol.....i need to do it kinda fast so i need to know exactly what im getting myself into......so if i swap the forks for the front suspension, everything will go on smooth? i dont need to mess with anything for the rear?
Old May 18, 2007 | 04:39 AM
they will unbolt from the del sol and bolt on the crx perfect just keep the front fork on that attaches to the strut
Old May 18, 2007 | 10:23 PM
1PT-SICK's Avatar
awesome! thanks guys.
ej6kid
Oct 26, 2010 03:42 PM
94eh2
Nov 4, 2007 08:13 AM
Groove_D
Jul 11, 2006 10:58 PM
RoadconeTuning
Jan 22, 2005 08:44 AM
