BAD GAS MILEAGE
Old May 14, 2007 | 08:09 AM
white99CF's Avatar
Default BAD GAS MILEAGE
HAVE A 91 ACCORD F22A4 wit very light mods intake, exhaust, ngk ignition
and am very curious as to y im gettin horrible gas mileage car has 215k on the dash but runs fine i do notice a slight miss at idle had the car for like 9 months, should i change timing belt???
Old May 14, 2007 | 08:52 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: BAD GAS MILEAGE (white99CF)
could try cleaning the EGR valve and the EGR ports. Check the FAQ for instructions on how to do this.
When was the last time the timing belt was changed? If you have never replaced it and you don't have anything showing when it was last replaced it might be a good idea to change that, the timing balance belt, tensioners and water pump as those should be replaced every 90,000 miles.
Old May 14, 2007 | 08:56 AM
white99CF's Avatar
Default Re: BAD GAS MILEAGE (TouringAccord)
yea u kno what i think imma gonna do the egr ports today ive been told that a few times as well and thas the only thing that i have checked since ive had the car and ill go ahead and change the timing belt as well thanks man for ur great help!!!!
Old May 14, 2007 | 08:59 AM
H-T Order of Merit
yep, np
if you haven't done a timing belt before, check out my write-up in the FAQ. It's on a F22B1 but it'll give you a good idea of whats involved and if you feel you can handle the job or not.
Old May 14, 2007 | 09:07 AM
white99CF's Avatar
coo man u think u could give me a hint to this problem as well when i decelerate at low rpms wit the car still in gear foot removed from clutch and gas, if feels as if the throttle is sticking to make the car still progress forward or could it be somethin wit the FLY
Old May 14, 2007 | 09:42 AM
H-T Order of Merit
I'm not sure. It's pretty quick and simple to clean the throttle body to make sure it's not sticking so you could do that just to make sure and see if it helps at all.
Old May 14, 2007 | 02:00 PM
tomcool's Avatar
My 94 Accord ex made 30mpg..nice..
WrenchinRosie
Jan 24, 2015 08:05 AM
georgiajdm
Mar 24, 2012 03:23 PM
txfl25
21
Jul 28, 2009 09:04 PM
newbster
Oct 13, 2006 09:43 PM
VtecAdvantage
Jul 15, 2006 02:01 PM
