replacing the master cylinder
i have never replaced the brake cylinder. I wanted to know if you guys had some advice or guidelines to watch out for when i do it. Is is just a matter of replacing the part and bleeding the breakes until theres no air in the lines?
dear dirty colombian (LOL)
bench bleed the master cylinder by running little tubes from the output nipples and looping them back into the reservoir. so you've got a little 'closed loop' system going on....
then you pump & pump the MC until you can't see any more bubbles coming out of the tubes into the reservoir.....the whole time you make sure to keep the reservoir about half full of fluid. it would help to hold the MC with a vise but i used my hip and braced it against my workbench.....whatever's clever
thanks i figured that out. basically how do u find out if its the master cylinder that is broken or the boost plate, or whatever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtycolombian »</TD></TR><TR><TD CLASS="quote">thanks i figured that out. basically how do u find out if its the master cylinder that is broken or the boost plate, or whatever
?</TD></TR></TABLE>
it depends on the symptoms you're having
?</TD></TR></TABLE>it depends on the symptoms you're having
ok what kinda symtoms should i be looking for? what i got is that the petal goes straight to the floor, you have to pump it for it to catch. Theres breaking fluid all over the master cylinder.
to me it sounds like the seal(s) in your MC are shot, it's not holding pressure, so you have to pump the pedal to stop....
if the booster was bad you'd get a stiff pedal or a hiss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtycolombian »</TD></TR><TR><TD CLASS="quote">ok what kinda symtoms should i be looking for? what i got is that the petal goes straight to the floor, you have to pump it for it to catch. Theres breaking fluid all over the master cylinder.
so its obviously leaking? from where?
test your booster:
and use a FLARENUT WRENCH when working on the brake lines. dont even THINK about using a regular 10mm open end wrench.
http://www.sears.com/sr/javasr...e=Yes
</TD></TR></TABLE>so its obviously leaking? from where?
test your booster:
its leaking from the seals. I bought the rebuilt guide and fallowed the steps to check the booster, the booster is fine. My concern is if there is air in the lines, would it be a safer bet me taking it to the mechanic? of course i rather do it my self. Thanks everyone for your response to my newbie a$$ question.
Doesn't sound like the booster going bad. The point of the booster is to make it easier to apply the brakes. When it goes bad, the pedal becomes harder to push, it doesn't go to the floor.
</TD></TR></TABLE>Doesn't sound like the booster going bad. The point of the booster is to make it easier to apply the brakes. When it goes bad, the pedal becomes harder to push, it doesn't go to the floor.
mingchi69
Jun 23, 2003 06:25 PM
