suggestions on how to solve o2 warning light
Old May 13, 2007 | 06:05 PM
hondacivic90zc's Avatar
Default suggestions on how to solve o2 warning light
my o2 sensor warning light has come on when i had the stock D15b2 in my 88 crx dx and it still comes on even after a sohc zc swap. I checked the fuel supply system (fuel pump, fuel filter, and fuel pressure regulator) how the manual says to do it and they checked out. I changed the o2 and when i did the old one's probe was very black which indicates mabye running rich and you can smell the gas when the engine is revved. I have also gone through three sets of used injectors that i had lying around and still the same problem. It only throws the code when the engine is warm and i am either at a steady rpm (cruising) or getting on the throttle and when i turn off the ignition and turn it back on it goes away.
If you have any suggestions i would really appreciate them.
altfuelneeded
Sep 1, 2011 08:54 AM
civiccarbuff
Sep 18, 2008 08:29 PM
ORcivicsi
Sep 12, 2003 09:35 AM
Litoman
Aug 15, 2002 07:53 PM
