Needing an OBD0 dizzy expert
Old May 13, 2007 | 05:17 PM
ludesrv's Avatar
Default Needing an OBD0 dizzy expert
I bought an OBD0 LS dizzy for my OBD0 LS powered hatch.
Thing is my harness has plugs for a OBD1 dizzy. I bought the dizzy already depinned aswell with OBD1 dizzy plugs to pin the OBD0 dizzy to OBD1.
Issue, I don't know which color does what. All the diagrams, write ups and everything else is for the engine harness, not the dizzy harness.
If anyone could tell me which color goes to which sensor. I figured out which groupings go together with a multimeter, I have them seperated into 3 groups, if anyone can confirm if they are correct.
Orange (pink) and white (TDC)
Orange (pink)/Blue and White/Blue (CYL)
Blue and Blue/Yellow. (CKP)
If anyone knows, sweet, if you don't, whatever. It's just a matter of time before I figure it out but I'd rather get it confirmed.
This dizzy wasn't all that good when I bought it. I should of opened it up before I payed for it. The rotor was loose and chewed the **** out of the cap. Good thing I only paid 20$ for it.
Old May 14, 2007 | 04:49 AM
ludesrv's Avatar
Bump?
Come on, I know someone here knows there ****.
I should say I lined up the colors to match an OBD1 plug I had lying around...as soon as I replace the cap and rotor I'm gonna try starting the beast up. See if it throws a code.
Old May 14, 2007 | 11:04 AM
jlicrx's Avatar
Default Re: (ludesrv)
<U>OBD1 distributor:</U>
CKP = blu/grn and blu/yel
TDC = orn/blu and wht/blu
CYL = orn and wht
IGNITER = yel/grn
<U>OBD0 distributor:</U>
CKP = orn and wht
CYL = blu/grn and blu/yel
IGNITER = white
Old May 14, 2007 | 11:20 AM
crx_si-r's Avatar
wat year is ur car? especially if u have an obd1 plug?
Old May 14, 2007 | 11:51 AM
ludesrv's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote"><U>OBD1 distributor:</U>
CYL = orn and wht
IGNITER = yel/grn
CKP = orn and wht
IGNITER = white</TD></TR></TABLE>
Again, I don't need the engine harness side I need to know the dizzy side of the deal.
Look at yours and tell me what wires do what (OBD0 dizzy).
Old May 14, 2007 | 11:53 AM
ludesrv's Avatar
Default Re: (crx_si-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">wat year is ur car? especially if u have an obd1 plug? </TD></TR></TABLE>
Check the sig, it's a 1990. I'm running obd1 plugs cause those are the only plugs I had lying around, obd1. The new harness had no dizzy plugs when purchased. It ran fine but threw code 4. OBD0 ecu need OBD0 dizzy.
Old May 14, 2007 | 12:56 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Look at yours and tell me what wires do what (OBD0 dizzy).</TD></TR></TABLE>the wire colors on the OBD0 are the same on the harness side of the connector as they are on the distributor side of the connector
Old May 14, 2007 | 01:42 PM
ludesrv's Avatar
jlicrx, you're my hero!
(sig that).
I followed your diagram, and it worked. Props go to you.
rpmraper
Jun 12, 2011 02:21 PM
enjoi_hendrix
Jul 16, 2009 06:02 PM
lileghatch
Mar 13, 2009 12:52 PM
onefastek9
Sep 15, 2008 05:41 PM
hatchboy
13
Feb 6, 2007 07:04 PM
