d16y8, first turbo set-up
Old May 13, 2007 | 05:01 PM
ridin98civic's Avatar
Default d16y8, first turbo set-up
gathering parts for my first ever turbo set-up.
the motor is a d16y8
so far the set up will be
greddy manifold check
greddy td04h check
k-teller 2.5 downpipe check
intercooler piping (ebay ETDmotors) check
generic FMIC (ETDmotors) check
RFL blow off valve check
lucas 440 injectors check
walbro 255 lph in tank pump check
stealthmode oil lines check
hallman pro RX boost controller check
crome tuned p28
UPDATE:
Modified by ridin98civic at 1:31 AM 6/14/2007
Modified by ridin98civic at 5:06 AM 6/16/2007
Modified by ridin98civic at 11:44 PM 10/26/2007
Modified by ridin98civic at 12:20 AM 10/27/2007
Old May 13, 2007 | 05:05 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: d16y8, first turbo set-up (ridin98civic)
1) You don't need an intercooler designed for a skyline, I hate seeing ginormous intercoolers.
2) Get a good tune from a reputable tuner.
3) Run crome, neptune or something.
Old May 13, 2007 | 05:10 PM
Default Re: d16y8, first turbo set-up (ek forever guy)
ahh yes, forgot about that, i will either be running a greddy bluebox, or a p28 w/s200. i just dont know if the s200 has the boost option and if it doesnt could i just use a missing link?
and for the intercooler i was thinking just a 25x6x2.5
Old May 13, 2007 | 05:15 PM
97Ej6mike's Avatar
Go sleeper status and custom fit a DSM or WRX style Intercooler down by the wheel well.
-Or-
I dont remmeber what company makes this, but therse a direct OEM style Intercooler that replaces the A\C Radiator, and looks JUST like it, but is actually an intercooler. Ill search and see if i can find it again.
Old May 13, 2007 | 05:27 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">ahh yes, forgot about that, i will either be running a greddy bluebox, or a p28 w/s200. i just dont know if the s200 has the boost option and if it doesnt could i just use a missing link?
and for the intercooler i was thinking just a 25x6x2.5</TD></TR></TABLE>
Id skip on the Greddy bluebox or missing link.
I would do a an OBD2-OBD1 Conversion harness w/ a P28 ecu chipped w/ Crome. It is a hell of a lot easier to use, and cheaper.
What kind of exhaust will you be using?
Internal or external WG?
The most important thing you need to remember/know is to get tuned! Your entire setup is worth nothing without it.
Old May 13, 2007 | 08:36 PM
Default Re: d16y8, first turbo set-up (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">
well i have a p28 socketed for hondata could i get it converted to crome? (dont know alot about tuning)
its an internal wastgate
exhaust is going to be a 2.5'' kteller d/p, no cat, 2.5'' maybe 3'' (&lt;which would be better?) all the way back to a box style muffler.
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">I dont remmeber what company makes this, but therse a direct OEM style Intercooler that replaces the A\C Radiator, and looks JUST like it, but is actually an intercooler. Ill search and see if i can find it again.</TD></TR></TABLE>
if you found out that would be awesome man.
Old May 13, 2007 | 08:51 PM
doood's Avatar
been there done that
Default Re: (ridin98civic)
if you already have a socketed ecu just find someone that tunes with crome
Old May 13, 2007 | 10:52 PM
vietelement's Avatar
Default Re: (doood)
nice u have almost the same setup as me, and a red civic haha
Old May 13, 2007 | 10:57 PM
Team RS2's Avatar
Default Re: (vietelement)
sell the socketed hondata ecu its worht money and go biuy another p28 from a junkyard,
i dont like neptune they are a little expesnive, crome or uber kickass ***, convert to obd1
skip on the side mount intercoolers or top mounts they just turn into heat sinks if you really want it to be a sleeper go buy some radiator paint
Old May 13, 2007 | 11:19 PM
nabin's Avatar
Default Re: (Team RS2)
booooooooooooost!
Old May 14, 2007 | 08:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">sell the socketed hondata ecu its worht money and go biuy another p28 from a junkyard,
skip on the side mount intercoolers or top mounts they just turn into heat sinks if you really want it to be a sleeper go buy some radiator paint </TD></TR></TABLE>
could i not chip the p28 i already have?
Old May 14, 2007 | 09:11 AM
1995Civic's Avatar
exhaust is going to be a 2.5'' kteller d/p, no cat, 2.5'' maybe 3'' (&lt;which would be better?) all the way back to a box style muffler.</TD></TR></TABLE>
Yes, you can send your ECU to a tuner and have them convert it to Crome. I like Crome a lot more, and is so much cheaper.
An internal WG is alright, but if you are going to be looking for real power at some point, that internal will have to go. It just doesnt stabilize pressure as well as an External and can cause serious boost spike.
For your exhaust, I would skip the 2.5" and go right to 3" all the way back. Unless you already have the 2.5" DP, I would keep it and run a 3" exhaust from Kteller.
Old May 14, 2007 | 09:22 AM
doood's Avatar
Default Re: d16y8, first turbo set-up (Francois78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francois78 &raquo;</TD></TR><TR><TD CLASS="quote">Sup everyone. I'm somewhat in the beginning stages of installing a turbo for my D16Y8, only has 40K miles on it. I've been doing some research on forums and other sites regarding turbos. I've seen a few complete turbo kits, one such as made by Edelbrock, get around 6-7psi without changing interns. I've noticed some prefer buying components seperately. Is there a difference, complete sets vs individual parts? </TD></TR></TABLE>
way to hijack someone else's thread
Old May 14, 2007 | 09:24 AM
1995Civic's Avatar
Default Re: d16y8, first turbo set-up (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
way to hijack someone else's thread</TD></TR></TABLE>
Word.
1) If you DID research, you will know the difference.
2) You cant just come in a Hijack someone's thread.
3) Just no.
Research, and note the differences. If you still have questions, come back and make your own thread.
Old May 14, 2007 | 10:46 AM
haha thanks guys,
i will already have a the 2.5 kteller d/p so i should just run 3" after that?
also i probably will have this ecu converted to crome.
as for the wastegate, im just looking for a little over 200 hp. would the internal wastegate be an issue?
Old May 14, 2007 | 11:15 AM
Ek Forever y0!
for 200whp an internal wastegate will be fine.
Sounds cooler imo
If you intend to do a mild build: valves, retainers, headstuds, etc. Then you'll want an extrenal wastegate for safety reasons and a 3" exhaust will really open it up.
My friend anthony in PHX is running 550whp on his d-series, 32psi sleeved etc etc and he's got a 3.25" exhaust with 2-36" resonators.
Bitch is silent. Never imagined that purple hatch would run 10's.
Old May 14, 2007 | 11:45 AM
as of right now i have a crower stage 2 cam with crower springs and ti retainers. not real sure if ill be able to run that cam tho since it is an NA cam. but plan on leaving the springs and retainers alone if i do put the stock cam back.
Modified by ridin98civic at 2:15 AM 5/18/2007
Old May 14, 2007 | 01:11 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">haha thanks guys,
as for the wastegate, im just looking for a little over 200 hp. would the internal wastegate be an issue?</TD></TR></TABLE>
As Ek forever guy said, an internal wg will be fine w/ 200whp. I was just saying as you want more power, you're gonna want to run an external.
Ok, since you have the 2.5" DP, just run 3" exhaust and it will sound very pleasant...this is what i have currently until i upgrade to a 3" DP
Old May 14, 2007 | 03:20 PM
EJ1_Ex's Avatar
i have the same setup but with a external wastegate welded to the cast iron manifold, and welded shut the internal on the turbo..but 200whp should be fine with that set-up.
Old May 14, 2007 | 08:28 PM
EX-T's Avatar
Default Re: (EJ1_Ex)
You're gonna become addicted to boost!
Old May 14, 2007 | 08:45 PM
Default Re: (EX-T)
haha i know, thanks for answering all my noobish questions
Old May 14, 2007 | 09:07 PM
http://cgi.ebay.com/ebaymotors...08431
what do you all think about this intercooler?
Modified by ridin98civic at 7:32 PM 5/15/2007
Old May 17, 2007 | 07:08 PM
EX-T's Avatar
I would jump on it.
Old May 17, 2007 | 08:58 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...08431
Modified by ridin98civic at 7:32 PM 5/15/2007</TD></TR></TABLE>
That's a perfect sized intercooler for your car.
I would definitely jump on that deal...perfect height, width, length. Good find
