Mig and stainless?
Old May 13, 2007 | 04:56 PM
MidwestAutoWorks's Avatar
Default Mig and stainless?
Anyone here mig with stainless.
I just bought the Lincoln 175HD and with the help of tony1 I bought some sch40 SS pipe(kidding I bought 16ga) for my 3 inch turbo back exhast for my s2000. Id like to piece together and weld it myself with the welder I just bought. Or should I just tack it and then take it somewhere to get tigged?, its going to be 3 pieces with two V bands.
Old May 13, 2007 | 04:57 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Mig and stainless? (MidwestAutoWorks)
you can use 308L wire.
im pretty sure my weld pak 175 is basically the same thing as your 175HD
Old May 13, 2007 | 05:01 PM
Default Re: Mig and stainless? (E-Rok)
did you get it at home depot?
if so then yes it is just repackaged
Old May 13, 2007 | 05:03 PM
what size wire?
Old May 13, 2007 | 05:12 PM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">did you get it at home depot?
if so then yes it is just repackaged</TD></TR></TABLE>
yea its from HD. .025 wire works fine.
Old May 13, 2007 | 10:00 PM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">Anyone here mig with stainless?</TD></TR></TABLE>
Its pretty straightforward. Shield with argon and practice a bit to get the settings right. On thinner stuff, its easy to blow it out if you are not careful, but once you get it down, its cake. I have seen several threads on it before, so a search might get you some more specific info.
Best of luck with your project.
Old May 14, 2007 | 03:58 AM
ManBearPig4silly's Avatar
I use a helium mix for stainless. Its really not that much harder than mild steel.
Old May 14, 2007 | 10:14 AM
Ohgodzirra's Avatar
Default Re: (ManBearPig4silly)
Tony, (wisconsin tony not tony1) there is a really nice welding place in tosa, and another one on hampton out in butler I believe, they are super helpful and will carry alot higher quality stuff than what home depot has to offer.
Old May 14, 2007 | 01:11 PM
arcboy's Avatar
New User
Short circuit on stainless is going to be a spatter machine.
Pulsed or Pulsed Spray is the only way to GMAW stainless
If you want any quaility than you really should get a hold of a GTAW welder.
Old May 14, 2007 | 01:32 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Mig and stainless? (arcboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcboy &raquo;</TD></TR><TR><TD CLASS="quote">Short circuit on stainless is going to be a spatter machine.
If you want any quaility than you really should get a hold of a GTAW welder. </TD></TR></TABLE>
TIG is def the way to go. I only use my MIG for mild steel
Old May 14, 2007 | 04:34 PM
hucoreyCRX's Avatar
If you want to use wire for stainless, I personally use a high end material called Addifix 942. You can get it in .035 that has a flux core. No, this is not the typical flux core that people assume is gasless. It is a dual-shield type. Meaning you need at least 75/25 or straight 100 argon plus you have the inner core flux. When set correctly, you will have absolutely no spatter. It is a bit pricy though. About $40 per lb.
Old May 15, 2007 | 03:11 PM
arcboy's Avatar
New User
Default Re: Mig and stainless? (hucoreyCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hucoreyCRX &raquo;</TD></TR><TR><TD CLASS="quote">If you want to use wire for stainless, I personally use a high end material called Addifix 942. You can get it in .035 that has a flux core. No, this is not the typical flux core that people assume is gasless. It is a dual-shield type. Meaning you need at least 75/25 or straight 100 argon plus you have the inner core flux. When set correctly, you will have absolutely no spatter. It is a bit pricy though. About $40 per lb. </TD></TR></TABLE>
What kind of range does this have? I guess I should say how thin of material can it be used on?
Old May 17, 2007 | 06:57 AM
DSMu4ia's Avatar
I've migged up 304ss while "playing" around in welding class.
We were using 100% argon, and whatever wire they run as default in the welding class machines (usually welding 1/4" mild steel plate). It was either .030 or .035 wire.
You definately have to play around with the machine a bit initially, it's really easy to get burn through and a lot of penetration.
Attached is a pic, that shows the penetration. This is way too much, but it's about the best I could do. This was with the torch about 1" off the surface which is as high as I could go without losing the shield.
Note: I only did this to see what migging up tubing was like, I quickly moved onto TIG and never looked back.
HiProfile
Welding / Fabrication
Nov 27, 2007 04:13 PM
Quickgti1.8t
Nov 24, 2006 04:18 PM
c0mbo
Honda Civic (2006 - 2015)
11
Jul 24, 2006 11:06 AM
JDM_Frijoles
May 18, 2006 10:17 PM
JDM_Frijoles
May 18, 2006 09:37 PM
