b18b into a sedan. please help a novice
Old May 13, 2007 | 01:30 PM
stemiched's Avatar
Default b18b into a sedan. please help a novice
Alright so im getting an ef sedan for the low low price of free and am hoping to get a 4k$ loan.
my plans are to swap a b series into the car. right now im thinking of a b18b, i deffinately want to get one of hmotorsonline so it has low millage and thats all they have in stock as for b series in my price range.
im making sure to source out my parts before i buy anything at all so guys help me make sure my parts list is corrrect.
Motor
B series mounts
da integra axles from my local parts store
p75 ecu (is this the correct/best one for a b1b?)
0bd0-0bd1 conversion haness ill probably buy from hasport
hasport shift linkage (i know i can modify the original shift linkage but im not ready to want to mess with welding so i think ill just buy a hasport one)
and i sourced out a B18A A1 5spd Cable Transmission, is this a good tranny? i was told i dont want a lsd tranny? is that tranny an lsd?
also i cant find an answer i understand to what the differance between hydrolic and cable transmission are... i assume hydro is better... is a hydro tranny any more difficult to install if i get the inovative mounts cable to hydro conversion?
and is there anything else im missing on my list?
im probably also going to get a new crossmember and eg half rad.
also will a b series fit under an ef hood? i really dont want to waste money on a hood...
Old May 13, 2007 | 06:18 PM
stemiched's Avatar
Default Re: b18b into a sedan. please help a novice (stemiched)
bump back up to page one.
what are the common things so replace when putting in a motor?
Intake manifold gasket
Exhaust manifold gasket
Cylinder head gasket
Valve cover gasket
Cam seals
Valve seals
Valve cover seals and grommets
Injector seat o-rings
thermostat
clutch
water pump
timing belt
upper and lower rad. hoses
anything else im missing?
i want to make sure i absolutely EVERYTHING sourced out before i buy a thing
Old May 13, 2007 | 06:27 PM
Crx Jimmy's Avatar
I would say the stuff below is neccesary, I dont think you have to mess with the other gaskets. I have never had a problem. You might want to rethink your b18, I would go with the b20 and get a b16, gsr or even better a type r transmission, the b18a tranny is probably the worst one you could get. get one (b16, gsr or R) with the 4.4 final drive, its much better. If you can afford the lsd go for it. I assume you have the mounts and shift linkage already, also dont forget to buy a 90 integra rear T transmission bracket and the timing cover mount bracket
thermostat
clutch
water pump and tensioner assembly
timing belt
Valve cover gasket
Cam seals
Old May 13, 2007 | 06:33 PM
stemiched's Avatar
Default Re: b18b into a sedan. please help a novice (Crx Jimmy)
no i dont have anything yet... not even the car its going in...
so your saying i should go with a b20 motor or a b20 transmission?
ill be getting the shift linkage from hasport, and most likely this mount kit from a h-t member
does that have all the mounts i need or do i need a dif. one?
the b18 tranny is only 450$ thats why i wanted that one... how much is a better tranny going to run me? and where can i source one out?
Old May 13, 2007 | 06:48 PM
stemiched's Avatar
would someone who knows all about this stuff mind talking to me on aim sometime?
screen name: smeisafreak
Old May 13, 2007 | 06:51 PM
Crx Jimmy's Avatar
for 450 you should be able to get a gsr or b16 tranny, I would go with hydro since they have more parts available, but then you couldnt use those mounts you would need hydro mounts, aslo you need the T bracket and timing bracket like I said earlier
Old May 13, 2007 | 06:57 PM
stemiched's Avatar
okay ill try looking for a b16 or gsr tranny.
so i would need this correct?
or should i be getting this?
or do i need both?
with that cable to hydro conversion thing they have is there any other work to put the hydro tranny in other than that conversion peice?
and whats the t bracket and timing bracket? are they not with that kit? if not where do i get them?
Modified by stemiched at 11:11 PM 5/13/2007
Old May 14, 2007 | 05:06 AM
stemiched's Avatar
bump back to page one.
do i need the mounts and the cable to hydro conversion thing or just the mounts?
assuming im going ot go with a hyrdo trannt
Old May 14, 2007 | 05:17 AM
89s1's Avatar
dude, you gotta search, the red buttom in the corner man, use it.... and dont just look at recent also look in the archives.
the more reading you do the more you'll save in cash. and just because that guy says he would go b20 doesnt always mean its the best idea.
the red button, push the red botton!
Old May 14, 2007 | 05:37 AM
stemiched's Avatar
Default Re: b18b into a sedan. please help a novice (89s1)
yea... i have been searching, there is absolutely nothing about b18b's
everything is about b16's...
Old May 14, 2007 | 07:20 AM
Brian Hinson's Avatar
All B series are the same concept... Except of course little things like the b20 intake mani an etc.
As far as mounts and the linkage situation, You would need all the same parts to swap either motor
If you get an older swap that comes with a cable trans, you shouldnt need any of the hydraulic kits... because im pretty sure an ef is a cable car.
Old May 14, 2007 | 08:58 AM
mahatma's Avatar
d00d shoot me an email, i'd be happy to answer all your questions, recap them for me.....i just can't do it on h-t here at work
kevin_27641@msn.com
Old May 14, 2007 | 09:00 AM
stemiched's Avatar
Default Re: b18b into a sedan. please help a novice (mahatma)
thanks man, ill e-mail you later tonight im at school right now and have no access for e-mail.
Project-89Honda
Jun 3, 2013 05:58 PM
stemiched
May 13, 2007 10:43 AM
kixcrx
Jan 15, 2007 08:43 PM
Sirfallsalot243
Northeast (Sales)
Nov 5, 2006 07:15 AM
89Si
Jun 6, 2002 10:06 AM
