tri-stage and single stage?
Old May 13, 2007 | 11:44 AM
mr. goodwrench's Avatar
Default tri-stage and single stage?
whats the different from a tri-stage and single stage paint? my car is going to get painted in a week or two [metallic white]. just want to know if one way is better than the other.
also how much paint do i need, any recommendation on the amount of BC/CC layers? its a 98 civic if that helps at all. thanks
Old May 13, 2007 | 12:19 PM
Efbluevtec's Avatar
Default Re: tri-stage and single stage? (mr. goodwrench)
there are single, 2 stage, and 3 stage.
Single- clear and paint mix together
2 stage - Paint first then Clear
3 stage- Base, Transparent color, clear
more for Kandy color paint jobs
dont get a single stage if you want a nice paint job. Thats a one day or ear scheib paint job
2 and 3 are the best
Old May 14, 2007 | 05:14 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. goodwrench &raquo;</TD></TR><TR><TD CLASS="quote">whats the different from a tri-stage and single stage paint? my car is going to get painted in a week or two [metallic white]. just want to know if one way is better than the other.
also how much paint do i need, any recommendation on the amount of BC/CC layers? its a 98 civic if that helps at all. thanks</TD></TR></TABLE>
Single stage is just like it sounds, you spray it on in one stage.
Two Stage is BC/CC, 3 medium coats of base, 2-3 wet coats of clear.
Tri-Stage can be base coat, transparent mid coat, clear coat, or base coat, transparent pearl coat, clear coat. Same rules apply, 3 coats base, usually 3 coats mid, then 2-3 coats clear.
If you're getting it painted metallic white, you'll most likely be using two stage, which is what most paint jobs are now a days.
It's hard to tell how much paint you will need for your car, you should also seal your panels before you lay down your color. 1-2 good coats of sealer, 3 coats of base, and 2-3 coats of clear, you're gonna use a decent amount of paint.
Old May 14, 2007 | 03:04 PM
thanks for the replies
Old May 18, 2007 | 08:36 PM
b20powereDA's Avatar
Default Re: (mr. goodwrench)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote">
It's hard to tell how much paint you will need for your car, you should also seal your panels before you lay down your color. 1-2 good coats of sealer, 3 coats of base, and 2-3 coats of clear, you're gonna use a decent amount of paint.</TD></TR></TABLE>
listen to this guy
Old May 19, 2007 | 07:49 AM
Genuine Rolla's Avatar
Default Re: tri-stage and single stage? (WihaSi)
pliskin8
Paint and Body
10
Dec 13, 2009 06:37 PM
EatSleepJDM
Paint and Body
24
Apr 7, 2009 06:42 AM
downeyballz
Paint and Body
Jan 26, 2008 09:06 AM
racebucket_eg
Paint and Body
45
Nov 9, 2007 04:14 PM
Adampops
May 17, 2002 05:01 AM
