o2 sensor-bank 1 sensor 1
Old May 13, 2007 | 09:26 AM
Bruce Lee's Avatar
Default o2 sensor-bank 1 sensor 1
I just got the code P0131. On a 1999 Honda Civic.
I know it has to do with the O2 sdensor. I'm not sure where this sensor is located. I know there are 2 of em.
Manual says closest to the cylinder head b4 the cat converter.
Where exactly is this located?
i reset the ecu, drive it like maybe 4 to 5 miles then the cel comes up, and the transmission act funny. therpm revs up the car won't move then it just kicks in and takes off, is that something like the limp mode?
Any tricks or anything I can do about this?
By the way this cil came on 1 day after I changed the oil. I had a hard time with the oil filter, etc. there is something going into the engine block right above the oil filter, is that maybe a o2 sensor?
Old May 13, 2007 | 09:38 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: o2 sensor-bank 1 sensor 1 (Bruce Lee)
Bank 1, sensor 1 is the pre-cat O2 sensor.
If you need an O2 sensor, sparkplugs.com has them for a good price. 10% discount code <U>srto2</U> on Denso or NGK O2.
Old May 13, 2007 | 09:49 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The above image is for an EX.
If your's is an LX, it looks to be in the Exhaust Manifold:
It also seems like there is a difference in part numbers for automatic or manual transmission.
Old May 13, 2007 | 11:22 AM
Bruce Lee's Avatar
Default Re: (tech8)
So #8 on that diagram is the one I'm getting code P0131?
Old May 13, 2007 | 11:24 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: (Bruce Lee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Lee &raquo;</TD></TR><TR><TD CLASS="quote">So #8 on that diagram is the one I'm getting code P0131?</TD></TR></TABLE>
Yes.
Old May 13, 2007 | 11:32 AM
Bruce Lee's Avatar
Default Re: (tech8)
I see, thank you. today i went working on it again. rest the ecu, run the engine for a while, like maybe after 2 minutes the light comes back on.
I took the connector off the sensoe and got a different code all toget ther, i think it was 65 or something which didn't help much. Do you think changing my oil had anything to do with the light coming on?
Old May 13, 2007 | 11:33 AM
Bruce Lee's Avatar
Also do you think this would affect the tranny, I mean when I drive sometimes with the light on, the rpm goes up the car doesnt want to move.
Old May 13, 2007 | 11:38 AM
Bruce Lee's Avatar
On sparkplug.com, it says rear and front. Which one would be the one for #8 on the diagram for the exhaust Manifold location?
Old May 13, 2007 | 11:50 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You want the front O2 sensor. Changing your oil would not cause the O2 sensor to come on, probably a coincidence.
The O2 sensor will cause the ECU to change its air/fuel mixture. With a bad O2 you may have a little poorer performance, poorer gas milage, and higher emissions. It should have no effect on the tranny.
Old May 13, 2007 | 11:05 PM
Bruce Lee's Avatar
Default Re: (tech8)
you think I need to replace both sensors or the one showing on the cel si the bad one?
Old May 14, 2007 | 01:59 AM
Vsm Hatch's Avatar
if you try to order the front one and the rear one on sparkplugs.com the part number that shows up is the same. So I'm guessing the before cat and after cat o2 sensors are the same. Sounds logical since the before cat o2 sensor is for closed loop adjusting fuel for optimum emisssions. The after cat o2 functions as a diagnostics to compare with the before cat to see if the cat is good or bad. Its supposed to make it easier for the smog/repair guys to find out if the O2 sensor is bad or the cat is bad or if its some other problems, but it cause more problems than it fixxes. Sucks for us obd2 guys.
Old May 14, 2007 | 02:05 AM
SkyliteCustomz's Avatar
if my bank 1 o2 sensor is bad..i'll just switch it with the bank 2 o2 sensor. PROBLEM SOLVED lol
Old May 14, 2007 | 05:31 AM
Bruce Lee's Avatar
Default Re: (SkyliteCP)
Yea man tell me about it, infact one would be enough, they just make things difficult. i was gona switch the connector for the 2, then i said lem me skip that little experiment, might get more cel's etc, and mess it up even more.
Old May 14, 2007 | 05:32 AM
Bruce Lee's Avatar
you know, lol.....haha that's something to give a try.
Old May 14, 2007 | 03:46 PM
haha give it a try and let me know how it turns out
Old May 14, 2007 | 06:59 PM
Bruce Lee's Avatar
By the way , what's the socket size to have this removed? any ideas?
Old May 14, 2007 | 07:08 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It's 22 mm (metric) or 7/8" (standard). Usually you use a special O2 sensor socket ($10), which has a slit in to to allow the wire to slide through.
If you remove the cover (#3), you may possibly be able to use a box end wrench on it.
The O2 sensor may be very tight, so you may need to use a breaker bar, or pipe (cheater bar).
Search google to get an idea what you are up against. If it is too tight, you may want to just have a mechanic do it. You don't want to round off the sensor or strip the thread in the O2 bung hole, which will be more $ and work.
Old May 14, 2007 | 07:47 PM
Bruce Lee's Avatar
Default Re: (tech8)
Hey there.
Thanks for the info. I think I'm a buy the part, then have a pro deal with opening it, etc. Don't want it to break and spend more $$.
Civic98KH
15
Dec 10, 2012 08:26 PM
92bseries
May 2, 2012 02:45 PM
Bruce Lee
May 13, 2007 11:05 PM
ezol
Acura TL, RL & ZDX
Apr 5, 2007 06:51 PM
jxkim89
Dec 30, 2006 02:55 PM
