tire size
Old May 13, 2007 | 08:41 AM
betta285's Avatar
Default tire size
would 205/50/16 tires be okay for 16x7 wheels? I want to maintain the stock diameter so that i don't throw off my speedo. I used a tire size calc and it came out fine. Just want to make sure.
Old May 14, 2007 | 06:01 AM
gulfview's Avatar
Default Re: tire size (betta285)
Yes. If you take a look at http://www.yokohamatire.com/utrimwidth.asp, the table will show that it will fit 5.5 to 7.0 wide 16 wheel.
Old May 14, 2007 | 06:10 AM
TouringAccord's Avatar
H-T Order of Merit
A 205 wide tire should fit onto a 7" wide rim but I would go with a 215/50/16 tire over the 205. The diameter is just slightly bigger (~.2") than stock so it won't affect anything.
You are also going to want to keep in mind the offset of the rim. That could have an affect on if you are going to rub or not.
Platinum.Skillz
Oct 31, 2007 11:52 AM
johnxboi
Apr 4, 2005 02:50 PM
dc5 jared
23
Aug 2, 2004 11:34 AM
GSR18
Oct 25, 2001 09:21 PM
thinkbrianthink
Jul 6, 2001 12:09 PM
