Eibach Sportline Springs!
Anybody has a picture of Eibach Sportline Springs on a 4th gen? I just installed mine with KYB AGX and it sits lower than I expected. I'm getting tire rub at all for corners when high speed cornering. My tires are getting cuts in them also! I'm running 215/40-17 on 17x7 with a 40 offset!
I have the same setup (kyb agx and sportlines) you can see photo's on page 13 of the picture thread.
my rims are stupid with 215x35x18 but I don't have any outer rub - not even the rears and I have 4ws too, I recently noticed I do have some inner rub, at sharp angle turning to the fronts. I plan on changing rims sometime.
I like the drop, but as most eibach users complain, the front sits a bit higher than the rear when it is first done, seems to settle out though. I wouldn't go any lower.
i have the sportline with the kyb...(silver's) mine sit lower in the back and have about a 2 inch clearance up front....i bought the car like that....i saw the spring's up front...and eibach is upside down...does that make a difference...?? and are the spring with less coil's supposed to be up front?? thanx
Zhu962
Jan 5, 2006 08:18 PM
