Broke my damn climate control lever tonight.
Old May 12, 2007 | 09:50 PM
justahobbie's Avatar
Default Broke my damn climate control lever tonight.
So the cold hot lever was on cold tonight, and i slid it over to hot and half way through...POP. The slider is now loose. Are the button lever assemblies the same between models, or are the Type R's different. The only reason I ask is it looks like the plastic and the bottons kinda look metalic and not just black. Or are they all like this...or did some girl put shimmer in my car...lol.
Anyway, I guess I need a new one if anyone has one. I guess I need to know if the carbon trim comes off. If so I can just go to a wrecking yard and get one and swap the trim.
Thanks
Old May 13, 2007 | 05:39 AM
AW's Avatar
AW
Default Re: Broke my damn climate control lever tonight. (justahobbie)
Check the cable attached to the slider underneath the passenger footwell. It sounds like you somehow disconnected it from the mechanism, if you did you can reattachit. Also, in generall all the climate control units are interchangeable. You just need to look for one with or without AC depending on if your car has it or not.
Old May 13, 2007 | 01:39 PM
Default Re: Broke my damn climate control lever tonight. (AW)
Ya, its connected. I manually slide that lever toc hange it from hot/cold. It's definately broken at the slider. Thanks for the info though.
Old May 13, 2007 | 01:47 PM
Dave_B's Avatar
You going to Expo? I've got one laying around if it's just the control unit.
Old May 15, 2007 | 02:09 PM
Default Re: (Dave_B)
I'm not...thanks for the offer though. Willing to sell? and ship?
I looked at it closer, and there is some metallic in the controls itself. Are LS, GSR's the same way? Or are they all black?
Old May 15, 2007 | 03:34 PM
SYTFU Tommy.'s Avatar
Default Re: (justahobbie)
they are all the same execpt got th 98+ buttons and some parts of the trim is gunmetal while the older ones are just plain black
dE.fUsEd
Aug 28, 2013 06:12 AM
1 Civic I
Aug 5, 2010 10:48 AM
DC206R
May 6, 2009 04:00 PM
blkegcoupe
Aug 26, 2008 05:01 PM
Project SSAP1
Dec 28, 2002 07:32 PM
