clutch not engaging?
alright i just bought and installed a stage 3 xtd clutch kit, my problem is the the fork is opening all the way like it should but the car wont go in gear like is it wasnt opening enough. btw it does go in gear wen the car is of so is not shift licage problem... any help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Janos Lin »</TD></TR><TR><TD CLASS="quote">Adjust ur clutch cable or you installed the throwout bearing wrong.
Janos</TD></TR></TABLE>
x2 did you put the bolt back in the arm for the throwout bearing
i never took the bolt out i used nose pliers.....ok so i never got it to work so i took the tranny out again and i installed small washers between the clutch and the flywheel i dont know how bad this it but it work, i got that tip from a honda dealership worker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slowass2dr »</TD></TR><TR><TD CLASS="quote">i installed small washers between the clutch and the flywheel </TD></TR></TABLE>????????????????????????????????
Washers? What the heck? Im not sure exactly where u put them, but you do relaize that sometimes there is a rotational difference between the clutch disk and the flywheel? That means sliding metal on metal contact, its either going to wear down or seize up.
Janos
Janos
Yaa
Nov 12, 2006 05:45 PM
vietnamese0utlawz
Oct 11, 2006 04:53 PM
