Something broken ? Belt // Pulley does not move ...
Old May 12, 2007 | 06:18 PM
street_ride14's Avatar
Default Something broken ? Belt // Pulley does not move ...
.. Moves very slow, snail like, after start up of engine. Was on a highway, took an exit, and my steering was hard. Looked under the engine .. PS belt came off, still in 1 piece. Alt and AC belt roatates like a snail, very slow. Rpms hold at idle, but belts won't move. When I Turn the engine off.. I can pull / rotate belt by hand.
What happened ? Auto tensioner belt went ? Need help ..
Old May 12, 2007 | 06:24 PM
Hawkze_2.3's Avatar
Default Re: Something broken ? Belt // Pulley does not move ... (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">.. Moves very slow, snail like, after start up of engine. Was on a highway, took an exit, and my steering was hard. Looked under the engine .. PS belt came off, still in 1 piece. Alt and AC belt roatates like a snail, very slow. Rpms hold at idle, but belts won't move. When I Turn the engine off.. I can pull / rotate belt by hand.
What the hell are you talking about?
Calm down and post a cohesive description of your situation so we can help you...
Old May 12, 2007 | 06:26 PM
Default Re: Something broken ? Belt // Pulley does not move ... (Hawkze_2.3)
Everything is there, what else?
Old May 12, 2007 | 06:31 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">.. Moves very slow, snail like, after start up of engine. Alt and AC belt roatates like a snail, very slow. Rpms hold at idle, but belts won't move. When I Turn the engine off.. I can pull / rotate belt by hand.
Those are the parts I don't understand...
The car accelerates slowly? The belts move slow, but the engine doesn't? You can pull the belt by hand meaning...it's very loose?
The auto tensioner is on the timing belt, not the accessory belts.
Old May 12, 2007 | 06:35 PM
No, the car drives, engine revs normally. When I stop, with the motor at idle, the AC / Alt belt moves very slowly.
Old May 12, 2007 | 06:37 PM
Hawkze_2.3's Avatar
It's moving slower than the engine? It should be squealing like a **** then...all the things you're saying are not making sense.
Old May 12, 2007 | 06:42 PM
c'mon man, try to imagine this. The belt moves like 1 mph, when it's really supposed to be moviing like 7 mph. It's almost like the crank pulley is not suppling enough energy / power for the belt to go any faster.
Old May 12, 2007 | 06:43 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">c'mon man, try to imagine this. The belt moves like 1 mph, when it's really supposed to be moviing like 7 mph. It's almost like the crank pulley is not suppling enough energy / power for the belt to go any faster.
If the crank pulley is spinning slower than it should, you have major problems...otherwise the belt is just slipping.
Old May 12, 2007 | 06:51 PM
Just noticed that I have shredded pieces of a belt comming out of the mid - timing belt cover. Will pull my valve cover tommorow to take a closer look, .. FACK,
Old May 12, 2007 | 06:54 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">Just noticed that I have shredded pieces of a belt comming out of the mid - timing belt cover. Will pull my valve cover tommorow to take a closer look, .. FACK,
Hopefully your timing belt is still intact enough not to bend any valves.
Acuranoob
K Series
Feb 6, 2015 11:03 AM
2007430
May 2, 2012 06:22 AM
needanew1
Jan 25, 2007 09:28 PM
D16z6PN
Apr 2, 2006 09:28 AM
chads
Jan 9, 2004 10:42 AM
